any helpful hints/tips for a first time competitor?
its a USAC event so i guess its db drag? so 30 second runs right?
how many runs do you get?
thanks for any help
First Gen Xterra: Always changing
DNX 690HD
RF 360.3
RF T3002
RF T4004
RF T10001bd
Silver Flute 6.5"s
Tang Band 1" Tweeters
Sundown X18 in 7cubes net tuned to 32hz
Trust me .25 Blows your Load.
thanks for any help
How many runs you get depends on 2 things, how many cars in your bracket & how far you can go. Tip# 1 good start Tip#2 good start
Edited by CHINO11550
H/U Pioneer deh80prs w/ HRT iStreamer Ipod DAC
Front stage is active, 4 Morel Elate 6.5" & 8 CDT DRT26 tweets
amp running 4mids, Mosconi Audio 300.2
amp running 8tit & alum tweets, Mosconi Audio 200.2
8 12" Ascendant Audio Chaos. amps 2 Digital Designs M4'z
box is a 4th order band pass
batts. 1 XS Power D3400 under hood,6 D3100 in back
2 XP 370 amp DC Power alts.
MLA module 15+volts
All in a 97 2door Tahoe LT
2010 West Coast Reg. 140-149.9 Bass Race Champ
Team Bass Hz
good to know. how are the classes arranged? by power, number of amps, number of batts, number of alts?
DNX 690HD
RF 360.3
RF T3002
RF T4004
RF T10001bd
Silver Flute 6.5"s
The comps that i have been to go by how loud your first run is
MLA module 15+volts
Team Bass Hz
oh i gotcha, i guess thats good, cuz i have a t1k but im only running it at 4 ohms and i didnt want to get put in a 1000 watt class when im only running 500 watts at the time.
DNX 690HD
RF 360.3
RF T3002
RF T4004
RF T10001bd
Silver Flute 6.5"s
so do i have to have a real cd? no ipod?
DNX 690HD
RF 360.3
RF T3002
RF T4004
RF T10001bd
Silver Flute 6.5"s
where is this at?
DC.jpgDC POWER
ok if its a usaci comp, they go by the 4ohm rating. it doesnt matter if it's wired down to .5ohm they will put you into a power class by the 4ohm rating. also where is you box? is it in the cargo area? is it below the window line? answer these questions and i can tell you anything you want to know about usaci
2000 gmc yukon
4 sundown Zv3 15's
4 dd m2a's
kenwood kdc-x994
2 batcap 4000's 1 batcap 2000
dual alts.
154@37hz and climbing
http://www.cardomain.com/ride/3231683
http://www.myspace.com/torque150
i just looked at your build. you will be in stock 0-600 for your burp class. and if you plan on running on music you will be in sb1. 0-600 you have 30 seconds to get the loudest burp score. you get 2 runs. use the first run and play track 19 on the cd they give you. it will tell you were your car peaks at. once you get your peak freq, say you peak at 37hz, then put the cd on track 37. now for sb, you want to find a song that plays in your peak freq. they will explain the rest there. hope this helps you.
2000 gmc yukon
4 sundown Zv3 15's
4 dd m2a's
kenwood kdc-x994
dual alts.
  • Who's Online   0 Members, 0 Anonymous, 5152 Guests (See full list)
