i have a pair old school 12'' orion xtr ferro injected cone subs..each sub is dual 4 ohms.. in a bandpass enclosure..
and i also have a old school 15'' kicker s15d sub.. in a decent 1.5 cu sealed box.. single 4 ohm sub..
and for the amp right now i have a 1200 watt sony xplod xm 2002gtr rated at 200 watts rms x 2 @ 2 ohm..and 5oo watts rms x1 @ 4 ohms.
will be changing the sony amp for a kicker zx750.1 amp next month.. its for my wifes 95 gmc jimmy..
and i can always build a different box for either of the subs if the boxes are not good enough.. im thinking definetly ported for the kicker sub even tho its not called for..?
whats your thoughts and opinions on what sub or subs i should use..? thanks.
4 15'' kicker L7 subs ( only 2 being used right now )
1 kicker zx2500.1 ( another soon 2 come )
box is 9.5 cubic feet slot portd thur the back seat
1 kicker zx650.4 amp powering 4 10'' ev dl10x mids ( rear deck )
1 kicker zx350.4 power 4 8'' beyma 8mi100 mid/highs ( 1 on each door )
2 runs of zero gauge wire ( about 60 feet total. )
big 3 done in zero gauge kicker wire
3 runs of 4 gauge for voice amps and eq' and crossover
2 kinetik hc1800 batteries in the trunk and 1 optima yellow top under the hood
260 amp irragi high output alternator ( soon to be 2 alt's )
alpine cda 9856 ipod headunit
kicker kx3 3 way crossover & a old school alpine 3342 digital 11 band sound field processor eq.
( search for ( 88bonnsse ) on youtube.com to see my videos..
according to my math, 14^2 is 196, 5.5^2 * 3.14 * 2 is 189.6. So the 15 will have more cone area. But id say its so close it doesnt really matter. So now its down to which are more efficient woofers, i would imagine that the more efficient woofers would be louder considering the power will be the same. Well. Those 12s will be wired to 1 or 4 ohms. What is the VC config of the kicker? If the kicker will wire to a final load of 2 ohms, go with the kicker. Otherwise youre getting way less power. Build a bigger ported box for the kicker.
  • Who's Online   0 Members, 0 Anonymous, 724 Guests (See full list)
