Most are fused at 10A i would think around 4A if you use the pre outs
lol that aint to bad, and everyone says caps only work if u get them full power well 400 amps is more then enuff for 5k watts.
and if my kenetiks dont work ill sell them too you cheap...just retail value haha :-D
Ride Stats:
2003 Ford focus Zx3 Hatch Walled System
X1 Solo X Kicker 18" "Enclosure: 7.8 cbft, Port Firing Into a Horn, On a 90*"
X1 Rockford Fosgate 40001bd "Now a Warhorse On my dresser"
x1 0g Big 3
x1 Kinetik 2400 "x4 Kinetik 2400's"
x1 Kinetik 1800
x2 Kinetik Special Edition True Silver Battery Terminals
x20 Gold Plated 0gauge 3/8 Ring Terminals
x25 Total ft: KnuKonceptz Kable 1/0 Silver Pearl* 2500+ Strands.
x15ft KnuKonceptz 8 Gauge.
-Soon Too Be Walled
Fav Quote:
They Dont Feal Me, But They Feal Me.
Usually as the impedance level of the load on the amplifier rises , the more dampening factor it will have. So yes 4 ohm theoretically should sound better then the driver wired down lower. However if you just want it loud.... your probably not going to hear the difference.
well its not only that but does anyone think a solo x 18 5k rms 10k max ported 35 hz, could handle 8k rms? plus thatd require me getting a 3 alt witch prolly would be uber uber expensive, Im not steve meade now lol...i aint got money like dat cat but i really want this setup
Ride Stats:
x1 0g Big 3
x1 Kinetik 1800
-Soon Too Be Walled
Fav Quote:
Set the gains correctly, use your brain when controlling the volume and you will be fine, with box rise the sub wont be seeing all 8krms anyways.
Too Much Stuff to list .
humm not bashing on the caps any here but hell you could get like 5 of the kinetik hc1200's.... or 10 of the hc600's..... i think it would be a little funny but would look better than a few caps linked together....
http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774
93 Saturn SC2My system4 SA-15's Walled
2 Cerwin-Vega S2000's
3 Kinetik Hc2000's
Dual 200amp alts.
you guys done with the peepee touching contest or do I need to end it?
Posted (edited)
ok yea i will go with kenetiks but...for 5k rms what size kenetic should i have? and i shoulnt have any voltage drop with my setup if im pushing 200amp x2 cuz 5k rms at 14 volts is 5000/14 = 357 amps so i got 43 extra amps powering my system.
that would be is the amp was 100% efficient... and it isnt. itll draw more amps than that. also if you have a 200amp alt, it puts out 200amps at full speed. so now at idle you have... lets say 100amps x2 so your at half the power you need.
remember it takes between 30 - 80 amps to keep a car running with AC and lights
so now you also need to take this into account. now you have 80amps that your car is using so at idle you only have 120amps with bolth alts.
edit: now with all these caps discharging and charging constantly, your alts will ALWAYS be charging a full capacity. my guess is you are going to burn up alts pretty quick.
Edited by skittlesRgood
Posted (edited)
yea i know but i plan to have 2 of them evenually and to get there full output i only have too run them at 2k rpms witch aint too bad bout driving speed.so say 400 amps and -100 amps or so from my car and radio so 300 amps and what ever my amp cant handle just gets set on the batterys witch i plan to have sufficient amount of...least for a good 5-10 minute 5k rms output would make me happy lol
what does a hifonics sampson draw at 5k rms on 4ohms then?can u find out for me?
WOULD my amp put more power out with the same current being hooked up at 1 ohm and taking the full 8krms from my amp or should i stick with 4ohms 5krms for higher damping factor?
Edited by solosickness
Ride Stats:
x1 0g Big 3
x1 Kinetik 1800
-Soon Too Be Walled
Fav Quote:
i looked, hifonics doesnt say a damn thing about efficiency.
did u check amp guts?
or
www.maxxsonics.com
i might be able to find it what would it look like to say the effencieny, like...what am i looking for? lol
Ride Stats:
x1 0g Big 3
x1 Kinetik 1800
-Soon Too Be Walled
Fav Quote:
Posted (edited)
or
www.maxxsonics.com
i checked at maxxsonics.
look for "XX% efficient"
i cant find anything for it :-( is that bad? are they hiding somthing? lol
Ride Stats:
x1 0g Big 3
x1 Kinetik 1800
-Soon Too Be Walled
Fav Quote:
