1999 Durango- Two 15" L5s Build Up
for raw sanding I use 60 grit then smooth it out with 120 then 400. I also use norton 3x sandpaper, it seems to hold up better
K cool I'll look for it at home depot this afternoon...You think with 60grit I'll be fine if were going to lay Vinyl over it? Would I need to use filler and all that stuff or sanding should do the trick?
it will show through with vinyl. you want the surface to be paintable smooth with vinyl. Once you knock it down with 60 taking the steps with 120 and 400 doesn't take that long but will look better. I would suggest the same steps in the port. I've never had a problem with fiberglass still being wet the next day.
  • Who's Online   1 Member, 0 Anonymous, 959 Guests (See full list)
