Blazer + 4 Fi BTL 18s= FUN!!!
Well i have some down time seeing that I'm not working right now and I'm waiting for my amp and wire. I decided to finally fix my alt setup. I made the bracket out of bed frame lol so it wasn't the best it could be. So I figured I'd redo it. I found a place In town that sells all kinds of aluminum so I got some 1/4 angle aluminum. This is my old bracket..
99 2dr Blazer
Kenwood KVT-614
SounDigital SD16k
4 Fi BTL 18s
4 hertz high energy 6.5s comps
4 stock ad244 alts
6 g31s batts
8 runs 0ga
99 2dr Blazer
Kenwood KVT-614
SounDigital SD16k
4 Fi BTL 18s
4 stock ad244 alts
6 g31s batts
8 runs 0ga
Sweet. you know if you used smaller pulleys on your alts you would get better output at idle
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
I'll need a shorter belt dang
99 2dr Blazer
Kenwood KVT-614
SounDigital SD16k
4 Fi BTL 18s
4 stock ad244 alts
6 g31s batts
8 runs 0ga
Yup that was was my next question lol. How will the do on the highway tho with smaller pullies?
99 2dr Blazer
Kenwood KVT-614
SounDigital SD16k
4 Fi BTL 18s
4 stock ad244 alts
6 g31s batts
8 runs 0ga
Just measure your crank. You want it around 18k RPM at max rpm, so you divide the alt pully size into the crank size and multiply that by the max RPM of the motor.
If at first you do not succeed, you are doing it wrong! -ARS
Check out my walled TBSS build over here
4 Fi Team 18s on 2 Cactus K9
DS18 doors on 2 MBQ 1Ks, Vifa pillars on a STL4.500
Pioneer X8500
6 XS Power D7500, 1 3400S
Second Skin
2 270a Mechman Alts
i measured mine it measures 2"
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
He needs to measure his crank, it's not worth taking someones truck as an example and then finding out for some reason your crank is bigger or smaller. Smaller is no big deal (output will just drop), but bigger means you can blow up your alts (the rotor will explode).
Pioneer X8500
Second Skin
2 270a Mechman Alts
For example does irragi,DCpower,or mechman use different size pulleys on the same alternator for different cars? when i ordered my amputators they came with the same undersized pulleys regardless. I get were your coming from though :good:
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
DC Power and Mechman do not use the same pulley, Iraggi on the other hand... Well mine were doing around 30k RPM until I measured the crank and figured that out for myself. I made the mistake of trusting Dom to do the math, but he didn't so I blew 2 alts (when I say blew, I should say EXPLODED, the rotors were practically missing).
That's the only reason I know about it and why I suggest it time and time again, it only take a minute to measure your crank and it's way better than installing, blowing, uninstalling, shipping, waiting, reinstalling to figure it out ;)
In your defense though, a 2" pulley is pretty safe and I would guess his crank is small (unless it's a bigger OEM to "improve performance").
Pioneer X8500
Second Skin
2 270a Mechman Alts
  • Who's Online   0 Members, 0 Anonymous, 1010 Guests (See full list)
