no1singh123 Posted July 31, 2009 Report Posted July 31, 2009 hi there i been using carstereo to calculate a square port and i just wanted to know if i have done it right. The box measurements came to 6.14cft Height:15" Width: 35" Depth: 25" Square port measurements using http://www.carstereo.com/help/Articles.cfm?id=31 I just wanted to know if the sqaure port depth width and length are correct for the box and also including the port what does my cft come to Thanks EDIT : its for 4 12" Atomic Manhattan
IH8PunkRok Posted July 31, 2009 Report Posted July 31, 2009 well u need between 74 and 98 sq inches of port for that box.... u have 25 not good try it again with a bigger port -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
no1singh123 Posted July 31, 2009 Author Report Posted July 31, 2009 well u need between 74 and 98 sq inches of port for that box.... u have 25not good try it again with a bigger port Hi if you dont mind could you tell me how you worked out the sq inches of port so that i can work it out myself Thanks
Decaf Posted July 31, 2009 Report Posted July 31, 2009 12-16sqin of port per cuft of volume for slot and square ports 8-14sqin is great for aeros so 6.14cuft*12sqin/cuft = 74sqin of port to be tuned to 35hz
no1singh123 Posted July 31, 2009 Author Report Posted July 31, 2009 12-16sqin of port per cuft of volume for slot and square ports8-14sqin is great for aeros so 6.14cuft*12sqin/cuft = 74sqin of port to be tuned to 35hz i wanted to know how you would work out the sq inches of port i have as the previous poster worked out 25 sq inches of port what was the fourmla to work it out Thanks Edit : found out how to work it out its just height X width
Decaf Posted July 31, 2009 Report Posted July 31, 2009 ur defining port area... so Length X Width so 5in X 5in = 25sqin ud need 5in X 15in = 75sqin minimum
no1singh123 Posted July 31, 2009 Author Report Posted July 31, 2009 ur defining port area...so Length X Width so 5in X 5in = 25sqin ud need 5in X 15in = 75sqin minimum Thanks
