wrong section.. ill move it for ya
Aww you made my post go away explaining it......
Here it goes again
It really depends on your application and the ohms of the subs you will be running, the Kicker will do about 3000-3200 at 2 ohms the RF will do a little under 5000 at 1 ohm, so first what are you planning to push with these amps.
¿ǝɯɐƃ ǝɥʇ
Here it goes again
i have two re sx 15's, each 1200 rms runnin both subs at dual 2ohm, i dont want both, just seeing if any one has one for sale.
Here it goes again
Wrong and Wrong. Most Kicker Birth sheets Ive seen are no more than 2900 Watts max And not all T4ks will do 5000 watts..
Here it goes again
Im the mod.. :hi:
2007 Chevy HHR LT
UNDER CONSTRUCTION
1st Place Loud N Low 2010 MWSPL Finals
3rd Place Xtreme 3 2010 MWSPL Finals
Im sorry didnt mean to sound like you wanted both amps, if you are planning on sticking with those subs and not upgrading down the like I say the kicker would be a good bet, however if you plan on upgrading the RF would be a better choice since it does 3000rms or so at 2 ohms, then if you upgraded you could drop the impendence to 1 ohm and get alot more power.
¿ǝɯɐƃ ǝɥʇ
He didnt need exact numbers I just gave him sort of a ballpark, so to be a bit more specific the kicker is good for at least 2500rms up to about 3000rms at 2 ohms, the RF will do about 3000rms up to about 3400rms at 2 ohms and 4000 thru about 4700rms at 1 ohm, it all depends if you want to upgrade in the future.
¿ǝɯɐƃ ǝɥʇ
  • Who's Online   0 Members, 0 Anonymous, 691 Guests (See full list)
