How Many Runs?!?!?
Alright im be running 3 battteries a 145 amp alt im be running the zx2500.1 and the zx650.4 i was wanting to know if i do a run of 1/0 wire to disturburtiuon block and from the block to the 2500.1 use 1/0 wire and than 4 gauge to the 650.4 would that work or should i do a run to each amp and not have a distribution block???
Check out my build
http://www.stevemeadedesigns.com/board/ind...mp;#entry717600
4 12" Kicker L7's
1 zx2500.1 Kicker Amp
1 zx650.4 Kicker Amp
All Kicker 1/0 Wire
Headunit Jvc Kw-Nx7000
3 sets of 6.5 Image Dynamics CXS6 series
is one of your batts in the back? (im guessing so) if this is the case, then no need for the distro block. run the pos and neg from the amps staright to the back batt and you should be good.
Team Bass-Hz
ya one under the hood and the other 2 in the back
Check out my build
4 12" Kicker L7's
All Kicker 1/0 Wire
  • Who's Online   0 Members, 0 Anonymous, 1500 Guests (See full list)
