I was wondering if it was possible to use 10" speakers as mids. I have a good set of 10"s that still work. They are SVC 4-ohm and 350 watts max.
My comp setup (Not bad for what it is):
HP Compaq Presario V6120US laptop with:
15.4" widescreen
AMD Turion 64 X2 1.6GHz processor
2x1GB stick DDR2 SDRAM (667 Mhz)
Seagate Momentus 500GB SATA HDD
128MB shared video memory
Windows 7 Home Premium 64 bit
12 cell Lithium Ion battery (actual battery usage time: 6 hours)
What it does:
On a USB 2.0 Wireless card
yes you can use 10" as mids but what speakers do you have (name)
They're Jensen. They sound really good. I'm not sure of the RMS, but I think it's half the max rated.
15.4" widescreen
What it does:
sub woofers are usually better suited to play low, but there are a lot of 10 inch mids out there in the form of PA equipment that works fine in cars, hell, they even have up to 21 inch midbasses.
Team DC
So they should work pretty good. What frequency would ya'll recommend as the max?
15.4" widescreen
What it does:
70-200 hrtz maybe????
Hmmmm...I could probably get my dash and rear pillar speakers down as low as 300 hertz, but I'll have to test them to see if they sound good at that level. Ya'll think a little over 300 hertz would be all right?
15.4" widescreen
What it does:
