an amp that puts out 2000 rms at 2 ohms would give your subs about 1000 a piece...might I suggest take a look at diablo audio amps if you want to get another amp
either 2 HF 1000's or 1 HF 2500 would be awesome. :):)
Edited by shainemcconnell
2010 IDBL Rookie 1 North American Champion
2009 IDBL Rookie 1 Fl State Champion
2009 EBB Fly Weight 3rd Place Fl State Finals
2006 Silver Grand Prix GXP :Diablo Audio Hellfire 1000.1, JL Audio 300/4, One 13W7, ZR650, VR690, JL Cleansweep setup.
Team Pure Pressure
take the number of coils / the ohm load / the number of woofers = your final ohm load
so say 2 dual 1 ohm 15's
2 coils / 1 ohm / 2 woofers = 1 ohm final load
Wouldnt be thehoe92 without teh purple
ok i see now so im hooking up both coils on each sub but its still a 1 ohm load on each. creating a 1ohm total. so i need a amp that will do 2000 rms at 1ohm right
do not only hook up one coil...on each sub....Not a good thing. follow Exposport's pic post
for all (well a lot) of your wiring needs
http://www.the12volt.com/caraudio/woofer_c...sp?Q=2&I=22
use this and it will show you exactly what you are wiring to
Team Pure Pressure
you got dual 2 ohms. each speaker alone can be wired to 4 ohms or 1 ohm.
if you wire each sub to 1 ohm....then you can wire the subs into either 2 ohms or .5 ohms.
if you wire each into 4 ohms then you can wire the subs into either 8 ohm or 2 ohms,
use that link and you should get it right every time...:)
Team Pure Pressure
