1ohm and 2ohm
dirtboi22
It doesn't really work that way, I don't think you can wire a 2 ohm sub down to a 1 ohm (don't worry about peak output, worry about RMS)
2002 Toyota Solara SLE V6
Headunit - Pioneer DEH P3900MP
Door Speakers - Polk Audio db6501 6-1/2" 2-way
Component System
Rear Speakers - Polk Audio db691
Speaker Amp - DD C4b
Sub - 2 12" Alpine Type R's in a 2 @ 33hz
Sub Amp - DD M2A
Electrical - Big 3 - Stinger HPM 1/0 guage Wires, Optima Yellow Top Battery, 180/120 DC HO Alternator w/ MLA
Confuscious say "he who say it can't be done shouldn't be bothering man busy doing it"
Now feel free to go crawl back under that rock and leave this to the professionals....
refs: DC_Power_Kyle
when you only hook up one coil on a D2 VC it gives you a 2 ohm load but if you put both coils in parallel it gives you a 1 ohm load but the power rating wont change if you use both coils. it only changes if you use one
Team S.M.D.
Maritime Car Audio- (2) 18" SSA ZCON D1
- American Bass 500.1
- 60 ft of 3/0
-480 Ah of battery
- (2) stock alternators (70 +90)
- Kenwood Excelon x-794, 4v preouts
car audio is just a LOT more complicated than "this amp does this power" or "this sub will be this loud". its like 2 + 2 = banana. (if that confuses you then you get the point) lol
ok, so if you only have one side of the sub, or coil its at a 2ohm load. but if you have both sides of the sub hooked up(coils) its a 1ohm load?
it can be 1 or 4 depending on wether you hook the coils up in parallel or series
Team S.M.D.
- 60 ft of 3/0
-480 Ah of battery
a dual 2 ohm sub can be wired in parallel for a 1 ohm load, or in series for a 4 ohm load. it cannot get a 2 ohm load. the configuration of the sub is what determines the ohm load the amp sees. say an amp may put out 1000 watts @ 1 ohm, 500 @ 2 ohms, and 250 @ 4 ohms. wiring that sub in parallel (1 ohm) would give the sub 1000 watts. wiring it in series would give the sub 250 watts. but for a sub to take different power levels at different ohms is wrong. the AMP will put out different power levels, but the sub wont take more or less just because it's hooked up to 1, 2, or 4 ohms, etc.
  • Who's Online   0 Members, 0 Anonymous, 1576 Guests (See full list)
