Ok, so getting things going and have a few questions. I currently have 4 type r 12's, basically, 2 in each enclosure (2 combined enclosures) Each enclosure is 3.531 cuft internal, with 43.75 square incehes of port tuned to 38 hz. I inverted the subs to gain that .25 of internal space and liked the difference.
My first question....Would adding poly fill help even more?
2nd........would lengthening my ports help lower my hz?
And now getting away from the subs, I am running (4 pairs of componants, and 4 pairs of coax) 6.5 polk audios. Can the crossovers handle 2 6.5's and 2 tweets each, or do I have to run a crossover per each one? just trying to save some space, will have crossovers out the a--. And one last noob question, 1 6.5 speaker, with 1 tweeter, still 4 ohms? And if so, can I wire 2 6.5's with 2 tweeters to a 2 ohm load through 1 crossover to amp?
Thanks tons for any input....will have build log soon. dont want to bore people waiting for me to get all my parts :8)
06 2500hd, 6.0L, 4l80e, 4wd, (muah work truck)
7" BDS HC lift kit
(5) 37x13.5R18 Toyo Open Country M/Ts
(5) 18x10 Moto Metal MO962
tablet in lieu of deck
blue tooth interconnect to soundstream eq (for volume control and bass control)
4 Alpine type r 10's
6 cubes net, 80sqin's port, tuned to 33hz
2 brutus brx5000.5's
2 pairs 3" polk audio for a pillars
4 pairs polk audio 6.5 comps
1 pair 8" polk audio for mids
2 xspower d3400 batteries
.....learning alot from meade and his circle of some of the baddest installers ive seen- thanks guys, for not being so cocky and posting the way it should be done!
P.S. Thanks Steve....for the demo!!!! loud as fauk!
cant wait to see this. ive heard poly fill works better in sealed boxes and fiberglass enclosures, and as for the components idk if they can go down to 2 ohm or not, and idk about the crossovers but i would think as long as the crossovers got enough power to push 2 sets of components on one they should work, but i could be wrong. this is gonna be tits when you put up pics!
1997 Pontiac Bonneville Black on Black on Black
15" DC Sound Labs Level 5 w/ quad coil in a T-Line tuned to 35 hz
7" Jensen VM9311TS Touch Screen Flip Out w/ J-Link
Blue Custom Trim
Blue Custom Fiberglass Rear Speaker Pods
Autotek Mean Machine MM2000.1
1/0 Knukonceptz KLMX
Rockford Fosgate Twisted RCA's
2 Audiopipe Anl fuse holders w/ 200A Kicker fuses
2nd battery (Soon to be an Odyssey D3100)
Dynamat Extreme Bulk Pack
Custom False Floor
15% Tint All Around
Custom Painted Stock Rims
My Build Log
Tailights
15" Lvl 5 DC T-Line Build
Run one crossover per set or you will burn up the crossover.
Alternatively you can run either an active compatible head deck or a multi channel amp with full HPF/LPF and run 3-way active and ditch the crossovers altogether. :)
2001 Chevy Blazer
(2) SAZ-3000Ds
(2) custom 18" Madmax subs in a second row wall
Rockford 600-4
Pioneer PRS components
Pioneer P800PRS deck
Rancho cordova, sunrise and 50. but in construction, so all over from auburn to elk grove, eldorado hills to west sac
7" BDS HC lift kit
ahh, like that idea. just didnt want to run 8 cross-overs, ya know - thanks for that idea of getting rid of them all together
7" BDS HC lift kit
wrong section buddy go to subwofers/enclourses
sorry, still trying to figure this forum out. :pardon:
7" BDS HC lift kit
lol alright well i guess you learn something new everyday, yeah the amp idea sounds like your best bet
Blue Custom Trim
Custom False Floor
15% Tint All Around
My Build Log
Tailights
1st fiberglassing ive done, 8 of the coax's are going on the ceiling, can post teaser pics if needed. just waiting till farther along for full build :spiteful:
7" BDS HC lift kit
