I have a problem and maybe hopefully someone would know whats the problem :mad: ....
My battery keeps draining out on it own went to auto zone and aDvance to check my battery and alternator and comes out to be fine....There is nothing else connected to my truck right now just my alarm...do you guys have any idea on what it can be draining it out???? Need to get it fix before i can put my system in..
THANKS IN ADVANCE
Check out my build
http://www.stevemeadedesigns.com/board/ind...mp;#entry717600
4 12" Kicker L7's
1 zx2500.1 Kicker Amp
1 zx650.4 Kicker Amp
All Kicker 1/0 Wire
Headunit Jvc Kw-Nx7000
3 sets of 6.5 Image Dynamics CXS6 series
THANKS IN ADVANCE
if it was load tested (battery)and showed to be fine, you will have to check each individual circuit in your vehicle. check for power drain at your fuse panel (each and every circuit) with volt meter. may take awhile, but you will find the draining source.
06 2500hd, 6.0L, 4l80e, 4wd, (muah work truck)
7" BDS HC lift kit
(5) 37x13.5R18 Toyo Open Country M/Ts
(5) 18x10 Moto Metal MO962
tablet in lieu of deck
blue tooth interconnect to soundstream eq (for volume control and bass control)
4 Alpine type r 10's
6 cubes net, 80sqin's port, tuned to 33hz
2 brutus brx5000.5's
2 pairs 3" polk audio for a pillars
4 pairs polk audio 6.5 comps
1 pair 8" polk audio for mids
2 xspower d3400 batteries
.....learning alot from meade and his circle of some of the baddest installers ive seen- thanks guys, for not being so cocky and posting the way it should be done!
P.S. Thanks Steve....for the demo!!!! loud as fauk!
I dont think your alarm could do that even if it sat for a LONG while
7" BDS HC lift kit
I used to install for Circuit City, I've seen it happen.
Unplug your alarm and see what happens.
1996 Vw Jetta
Crunch 1500watt
1- Kicker 15" L7 @ 1ohm in a 4cu. ft. Ported Enclosure Tuned to 32Hz.
4- 6.5" Menace Door Speakers &
2- Menace super tweeters in the dash
139.11db @ 40hz (6/2010..old amp setup)
really? damn, didnt think there would be much of a current draw.
7" BDS HC lift kit
if you dont mind me asking where would it be plugged to???
Check out my build
4 12" Kicker L7's
All Kicker 1/0 Wire
Buddy of mine was telling me that it might be the voltage regulator on the altornator that gould be stuck and is draing out the battery..and when tested showed it was working fine since it is still charging the battery does that sound right???
Check out my build
4 12" Kicker L7's
All Kicker 1/0 Wire
its called a parasitic drain. its not THAT uncommon. i dont think its you alt. that sounds more like a guy that doesnt know and is trying to guess. we all do that some times. look up how to find a parasitic drain.
now if it is the alarm, is it fixable or is that just something you have to live with? i have a drain as well and i think its the alarm so this could help me as well.
Ok well its not the alternator cause i unplugged it like he said and still drained out last night im take it to where they installed my alarm and have them check it.... I cant live with that having it drain out everyday that just sucks
Edited by Guero3384
Check out my build
4 12" Kicker L7's
All Kicker 1/0 Wire
  • Who's Online   1 Member, 0 Anonymous, 3565 Guests (See full list)
