My alarm has the little spring thing that activates the alarm if the hood is popped and the alarm is armed. I noticed it was loose,so I screwed it in tighter and now it doesn't activate when the hood is popped. i also reloosened it. no luck
all wires are still connected to it
2 RE SE @ 32Hz
AQ 1200D
Image Dynamics Ctx65cs
Hifonics Zxi6008
make sure the area is free of rust and paint where it screws in because its contact points are the two bolts that hold it in
edit- thats what happened to mine but im too lazy to take the 15 secs to fix it god im worthless
Edited by Jville140db
Car is 2010 Scion Tc
Currently in car
Deck- Sony XAV-60 in-dash mobile video system
Speakers- Rockford Punch 6.5in comps in the front and coax in the rear
Subs- 2 Gen 3 Rockford P3 12's dual 4 ohm
Amps- Rockford P1000-1bd and P400-4 Alpine Mrp-f300 is in for P400-4 which is out to service
Wiring- all rockford nuff said
Enclosure- Dual 12in custom box by SRQ
Battery- Optima Yellow top with big 3 done
Sound Damping- All Dynamat products 1-2 layers throughout with liner on top
Link to my build log- http://down4sound.co...=newpost&t=5275
Link to my youtube- http://www.youtube.c...ser/Jville140db
MECP Advanced CEA # 110531
BassBox 6 Pro for Box Building/Re audio box calculator
If you can hear the passenger it aint loud enough!!!!!!!
QUOTE (MickyMcD @ Sep 25 2009, 07:25 PM) "My system has 30 speaker terminals, that means shits wanging doggggg....."<!--QuoteEnd--></div>
haha i'll check it out tmrw. i cant believe it'd be so simple.
i also can't figure out how the guy put the LED light by my clock. I can't remove it
2 RE SE @ 32Hz
AQ 1200D
Hifonics Zxi6008
If i had to guess, he removed the dash faceplate.
My comp setup (Not bad for what it is):
HP Compaq Presario V6120US laptop with:
15.4" widescreen
AMD Turion 64 X2 1.6GHz processor
2x1GB stick DDR2 SDRAM (667 Mhz)
Seagate Momentus 500GB SATA HDD
128MB shared video memory
Windows 7 Home Premium 64 bit
12 cell Lithium Ion battery (actual battery usage time: 6 hours)
What it does:
On a USB 2.0 Wireless card
what kinda car/truck/suv is this
Currently in car
96 accord. yea he drilled the hole because it use to be a solid piece
Edited by Fender
2 RE SE @ 32Hz
AQ 1200D
Hifonics Zxi6008
  • Who's Online   0 Members, 0 Anonymous, 3460 Guests (See full list)
