st185 Posted August 6, 2009 Report Posted August 6, 2009 Hi everyone, my name is Ignacio and i need some help from u guys. I have a Toyota Starlet 96 with a Sony CDX-GT460US headunit, a Kenwood Kfc-w3010 with a nice enclosure, 2 B52 ZR-695, and 2 Old Speakers in the dash (ill replace them soon) and my amp that is a SONY XM-ZR604 (its powering the subwoofer and the 2 B52 6x9s). I dont have much money to buy a new one, i have 250$us atm, so i was thinking on buyimg a new amp for my subwoofer, and use the Sony amp to power the 2 6x9s and power 2 mids that i want to buy and put them on the doors (the Sony amp is 4ch) so here is the question, considering that buying the new speakers will cost me like 50 or 60$us, can i buy something good with 200$ ? something nice for my subbie ? Thanks
enemyofsilence Posted August 6, 2009 Report Posted August 6, 2009 that sub is rated at 200w rms so i would match it up with this amp RF punch edit: what ohm is the sub? Team Bass-Hz
Jville140db Posted August 6, 2009 Report Posted August 6, 2009 I would have to say this http://www.sonicelectronix.com/item_17266_...+KAC-6104D.html its inexpensive only about 130-140 depending on where you live and will probably get the job done but their are better to be had may want some others to answer as well Car is 2010 Scion Tc Currently in car Deck- Sony XAV-60 in-dash mobile video system Speakers- Rockford Punch 6.5in comps in the front and coax in the rear Subs- 2 Gen 3 Rockford P3 12's dual 4 ohm Amps- Rockford P1000-1bd and P400-4 Alpine Mrp-f300 is in for P400-4 which is out to service Wiring- all rockford nuff said Enclosure- Dual 12in custom box by SRQ Battery- Optima Yellow top with big 3 done Sound Damping- All Dynamat products 1-2 layers throughout with liner on top Link to my build log- http://down4sound.co...=newpost&t=5275 Link to my youtube- http://www.youtube.c...ser/Jville140db MECP Advanced CEA # 110531 BassBox 6 Pro for Box Building/Re audio box calculator If you can hear the passenger it aint loud enough!!!!!!! QUOTE (MickyMcD @ Sep 25 2009, 07:25 PM) "My system has 30 speaker terminals, that means shits wanging doggggg....."<!--QuoteEnd--></div>
st185 Posted August 6, 2009 Author Report Posted August 6, 2009 its on my budget thanks for the reply man
st185 Posted August 6, 2009 Author Report Posted August 6, 2009 I would have to say this http://www.sonicelectronix.com/item_17266_...+KAC-6104D.html its inexpensive only about 130-140 depending on where you live and will probably get the job done but their are better to be had may want some others to answer as well Gettin Sony, Pioneer and Kenwood its pretty easy for me, the closest car audio shop sells those brands, unluckily there are no shops that have Rockford Fosgate, but if its the best option for my sub, then ill order one, not much problem
enemyofsilence Posted August 6, 2009 Report Posted August 6, 2009 well you dont have to go rockford. it was just a suggestion. but seeing that you live in bolivia and have sony, pioneer and kenwood there, then i would go with those. it would be easier on your part. just make sure the amp is 300w rms and you should be good to go. edit: it would be better if the amp was 200w @ 4ohm. just look around at what you have and try to match it up Team Bass-Hz
st185 Posted August 6, 2009 Author Report Posted August 6, 2009 that sub is rated at 200w rms so i would match it up with this amp RF punch edit: what ohm is the sub? sub is 4 ohm that amp is kinda expensive for me
