Need amp recomd
MXmike800
need an amp that will either do the following will be running 12 re re dvc4 ohm 12
150 rms each will be using 3 amps 4 subs per 1 amp
1k rms at .5 ohm
1k rms at 2 ohms
The only two that come to mind for me are the apline mrp-m1000 and the hifonics bxi1610 both should do around 1000@2ohms I dont know about anything that will run half ohm at 1000 that come to mind both of the amps listed are around 300 to 350 i think id take the hifonics personally
Car is 2010 Scion Tc
Currently in car
Deck- Sony XAV-60 in-dash mobile video system
Speakers- Rockford Punch 6.5in comps in the front and coax in the rear
Subs- 2 Gen 3 Rockford P3 12's dual 4 ohm
Amps- Rockford P1000-1bd and P400-4 Alpine Mrp-f300 is in for P400-4 which is out to service
Wiring- all rockford nuff said
Enclosure- Dual 12in custom box by SRQ
Battery- Optima Yellow top with big 3 done
Sound Damping- All Dynamat products 1-2 layers throughout with liner on top
Link to my build log- http://down4sound.co...=newpost&t=5275
Link to my youtube- http://www.youtube.c...ser/Jville140db
MECP Advanced CEA # 110531
BassBox 6 Pro for Box Building/Re audio box calculator
If you can hear the passenger it aint loud enough!!!!!!!
QUOTE (MickyMcD @ Sep 25 2009, 07:25 PM) "My system has 30 speaker terminals, that means shits wanging doggggg....."<!--QuoteEnd--></div>
Run 2 big amps, 6 subs on each amp. You'll get a 1.333 ohm load. Something like a pair of DAT2500.1's or SAZ2000D's would do it.
Or run 1 enormous amp. Maybe a DAT8.1 and run it at 0.666 ohms. How badass would that be :)
10.x volts fo' life!
  • Who's Online   0 Members, 0 Anonymous, 673 Guests (See full list)
