liftedranger08 Posted August 10, 2009 Report Posted August 10, 2009 Im getting 4 q power 15s dual 4ohm here shortly and im gona run about 1000 watts to each. What are some good 4000 watt amps that are relatively cheap but put out rated power. If im going with 4 with dual 4 ohm, would i be better getting 2 2000 watt amps at 1 ohm or can 4 dual 4ohms be wired down to 1 ohm? 2000 White Ford Ranger 5" RCD lift 33x12.50 Mickey Thompson MTZs on 16x8 Mickey Thompson Classic 2s Euro Altezza tail lights 5% window tint Clarion Indash 4 Q Power 15s 1 Sundown 2000 1 DC power 300 amp alt(on the way)-soon to be 2 2 powermaster d925s batteries Second Skin Deadener Highs/mids amp-Crossfire 404 Door speakers-2 5x7 mb quarts and 1 5 1/4" black max up front, stock 5x7s in the rear Soon to Come: Lots of SA-8s 2 Sundown saz 3500s(possible 4500s) 5-7 d3100 batteries custom clamshell BNC 8s for mids undecided tweeters
Kvo_8 Posted August 10, 2009 Report Posted August 10, 2009 http://www.soundkraft.com/Subwoofer_Wiring.htm Alpine 9886 Polk Audio 6.5 Component db series Elemental Designs nine.4 JL Audio 1000/1 DC Lvl 4 15" - 3.95 cu ft/tuned to 32 hz Clarion EQS746 Stinger Voltage Meter Optima Yellow Top (Front) XS Power 1200 (Rear) All KnuKonceptz Wiring
tibs Posted August 10, 2009 Report Posted August 10, 2009 if dual 4's run 2 amps strapped on 2 ohms Tibs 99 F-150 Build 8 twelves 8 - Re SE 12"s 2 - SunDown Audio Saz-3000d's 1 - vx4004 planet audio amp big 3 1/0 gauge MECHMAN 250 amp alt MySpace
