Cdizzle Posted April 6, 2007 Report Posted April 6, 2007 Right now I have a Kicker Comp VR hooked up to my SoundStorm F2800 amplifier. I was wondering how much of a difference it would make if I bought the Kicker ZX-750.1 amplifier. I have the subwoofer hooked up pulling a 2 ohm load from the amp... Let me know if anyone can answer this question...Thanks. Cameron Quote Damn Thiefs
Chris Posted April 6, 2007 Report Posted April 6, 2007 (edited) The CVR isn't rated to handle 750 watts RMS, plus that amp is CEA-certified which means it is underrated. Also, I cannot stress enough the fact that MAX power on ANY amp DOES NOT exist. Edited April 6, 2007 by Chris Quote 4 15" FI Q D2's in 12 cubes tuned to 32hz 1- T1000.1bd's 3 Maxx 29 deep cycles 4 runs of 1/0 gauge -Big 3 -Trunk sealed off from the cabin Custom 15.8 dual-volt switching MLA module All in a CAR.
Cdizzle Posted April 6, 2007 Author Report Posted April 6, 2007 The CVR isn't rated to handle 750 watts RMS, plus that amp is CEA-certified which means it is underrated. Also, I cannot stress enough the fact that MAX power on ANY amp DOES NOT exist. Well what kind of kicker amp do you suggest. I know that the Max power does not exist and that you should always go by the RMS. I contacted Soundstorm and the guy told me that none of their products are CEA-certified cause they didnt wanna pay the extra money... Quote Damn Thiefs
Chris Posted April 6, 2007 Report Posted April 6, 2007 Yeah, Soundstorm isn't as badly overrated as a lot of companies out there. If you wanna stay with kicker, go for the ZX400.1. It'll put out around 450-500RMS at 2ohms. Quote 4 15" FI Q D2's in 12 cubes tuned to 32hz 1- T1000.1bd's 3 Maxx 29 deep cycles 4 runs of 1/0 gauge -Big 3 -Trunk sealed off from the cabin Custom 15.8 dual-volt switching MLA module All in a CAR.
07mazda3s Posted April 6, 2007 Report Posted April 6, 2007 Well what kind of kicker amp do you suggest. I know that the Max power does not exist and that you should always go by the RMS. I contacted Soundstorm and the guy told me that none of their products are CEA-certified cause they didnt wanna pay the extra money... The soundstorm is prolly producing more than enough power to get max performance out of one CVR. Getting a more expensive amp might clean up the cvr a little bit but its not gonna get much louder if it does at all. Quote Power Acoustik fubar 12 sony xploding amp 2 ft^3 box @ 35hz
Cdizzle Posted April 7, 2007 Author Report Posted April 7, 2007 The soundstorm is prolly producing more than enough power to get max performance out of one CVR. Getting a more expensive amp might clean up the cvr a little bit but its not gonna get much louder if it does at all. Well, the guy at Circuit City that installed the sub cause i kept hooking it up wrong, said that this amp that I have now is not maxing it out, he said that it wasnt even close... He told me they have a nice kicker amp but didnt recommend a series/name. Can you guys tell me how to check the RMS with a multimeter? Quote Damn Thiefs
Cdizzle Posted April 7, 2007 Author Report Posted April 7, 2007 Yeah, Soundstorm isn't as badly overrated as a lot of companies out there. If you wanna stay with kicker, go for the ZX400.1. It'll put out around 450-500RMS at 2ohms. Plus I wouldnt be able to run the sub at 2 ohms, that is if I got the ZX400.1 because, it is dual 2 ohm voice coils.... Quote Damn Thiefs
Chris Posted April 7, 2007 Report Posted April 7, 2007 (edited) Right now I have a Kicker Comp VR hooked up to my SoundStorm F2800 amplifier. I was wondering how much of a difference it would make if I bought the Kicker ZX-750.1 amplifier. I have the subwoofer hooked up pulling a 2 ohm load from the amp... Let me know if anyone can answer this question...Thanks.Cameron Plus I wouldnt be able to run the sub at 2 ohms, that is if I got the ZX400.1 because, it is dual 2 ohm voice coils.... Well then how is it pulling a 2ohm load from the amp? There is no way I could have known what coil configuration you have or that you have one coil going to each channel since singular and plural expressions were mixed up somehow. Edited April 7, 2007 by Chris Quote 4 15" FI Q D2's in 12 cubes tuned to 32hz 1- T1000.1bd's 3 Maxx 29 deep cycles 4 runs of 1/0 gauge -Big 3 -Trunk sealed off from the cabin Custom 15.8 dual-volt switching MLA module All in a CAR.
Cdizzle Posted April 7, 2007 Author Report Posted April 7, 2007 Well then how is it pulling a 2ohm load from the amp? There is no way I could have known what coil configuration you have or that you have one coil going to each channel since singular and plural expressions were mixed up somehow. Since it is a 2 channel amp, I have the dual 2 ohm coils on the sub hooked up making it a 4 ohm load, once bridged to the amp it pulls 2 ohms from the amp. That is how circuit city hooked it up and explained it... Quote Damn Thiefs
Chris Posted April 8, 2007 Report Posted April 8, 2007 Circuit city lied to you. You cannot have a 2ohm load on the amp if your subs are wired to make a 4ohm load. It's either/or if you only have one sub and since you have dual 2ohm voice coils, it's either a 4ohm load or a 1ohm load. Quote 4 15" FI Q D2's in 12 cubes tuned to 32hz 1- T1000.1bd's 3 Maxx 29 deep cycles 4 runs of 1/0 gauge -Big 3 -Trunk sealed off from the cabin Custom 15.8 dual-volt switching MLA module All in a CAR.
