is there a difference between them? if so, which is better for what and what does each do? annnnddd could you name of some of the better brands for them? i've seen pioneer EQs and soundstorm epicenters but i'd like some better brands.
1994 Ford F150 reg cab
2 HFX 12's
Audiopipe APSM-1300
when it comes to epicenters audiocontrol is the best one, audiocontrol also has very nice eq's
98 Toyota Camry
Eclipse AVN-6600
AudioControl 3.1
AudioControl Epicenter
US Amps AX2000
US Amps MD-43
1 set Alpine type X components
1 set RF Power components
1 12" RE Audio XXX
220 Amp Iraggi Alt.
Red Top (Front)
Kinetic HC-600 (Back)
Second Skin Damplifier Pro
come to think of it, i think i did see an audiocontrol one. idk. but what's the difference between them?
2 HFX 12's
Audiopipe APSM-1300
EpiCenters are usually just a bass EQ. They do the exact same thing but only go from like 20-100hz. Often they can provide a lot more boost than a normal eq - like up to 18dB so you can get bass from a non-bassy song and look like a complete idiot :P
10.x volts fo' life!
Why would you look like a complete idiot?
98 Toyota Camry
Eclipse AVN-6600
AudioControl 3.1
US Amps AX2000
US Amps MD-43
1 12" RE Audio XXX
220 Amp Iraggi Alt.
Red Top (Front)
so i take it that if i wanted to.......play owner of a lonely heart like King Of Bass did, i need one of those? i wouldn't mind it.
2 HFX 12's
Audiopipe APSM-1300
Man I have an epicenter and love it.
98 Toyota Camry
Eclipse AVN-6600
AudioControl 3.1
US Amps AX2000
US Amps MD-43
1 12" RE Audio XXX
220 Amp Iraggi Alt.
Red Top (Front)
just make sure to spend time researching a good one.
I bought the clarion eqs746 and it completely robbed me of my lows like 32 and below were struggling.
I would say if you got an EQ use it for the mids and highs and then buy an epicenter for the lows :D
Wouldnt be thehoe92 without teh purple
dosent the epicenter raise the input voltage, up to 9v? .... im also wondering what good this would do... and what about the bass cube?
http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774
93 Saturn SC2My system4 SA-15's Walled
2 Cerwin-Vega S2000's
3 Kinetik Hc2000's
Dual 200amp alts.
you guys done with the peepee touching contest or do I need to end it?
