do you think its ok to run an amp at 1/2 ohm,... the amp is a AQ2200d,,,,an the subs are two treo ssx 18" duel 2s.. i will have 2 of the amps and four subs,,,i have a 240 amp alt and two Vmax 1800 batts just for these
dont do it.that amp may not like it being ran at 1/2 ohm.your electircal looks decent to support it.
That's why they don't deliver.
Yer ass better go sit along the side of the road and wait.
You can't expect them to travel up some dirt road in a hick / back woods town. Thats how horror movies start :D
I explain things very simply and use analogies in terms of Pickles, and grape drink, pool noodles and jackhammers...if you can't put 2 and 2 together there man, There simply is not much more I can do.
i called aq and they said it would be ok if my voltage stayed ok,,,and i didnt push it to hard for to long with out letting system recharge
There is no way that electrical can hold up to 2 amps wired at half ohm and if the amps not rated for it.... It will in time fail I.e blow
i was just talking about one,i know it wont be able to take two.but did you tell AQ what kind of electical you had when you told them that?
the aq amps are just like the m series amps from dd. they love .5 but you have to have the electrical to back it up. i have been running my m3's at .5 for close to 3 years now. they can handle it just fine. and yes that came straight from dd. they just wont warranty an amp that has been ran at .5 due to people blowing them up with not enough voltage
2000 gmc yukon
4 sundown Zv3 15's
4 dd m2a's
kenwood kdc-x994
2 batcap 4000's 1 batcap 2000
dual alts.
154@37hz and climbing
http://www.cardomain.com/ride/3231683
http://www.myspace.com/torque150
yah,,, i told DJ at aq what i had,, he said it should be ok,,,but true on the warrenty part,,,what would be the easiest way to help this prob out
if i dont have the electrical system to support it ..what will help,,,more batts or what i have duel alts,,, but my stock alt is just running my truck,,,the other 240 is just for the subs
