Stripped a screw
white4d96
Okay, so I was messing with my amp the other day, trying out different setups for when I don't have as much trunk space (i.e. where to put the damn thing) and I go to tighten the negative speaker wire down and...it doesn't tighten. When I pick the allen driver up the screw comes with it, and the threads on the amp side are GONE.
OH SNAPZ SUMWUNZ STOLD DEMZ!!!
Joking aside, I was wondering if there was any particular material of screw I should look for to go in its place and/or any specific method for retapping the hole, or if I can just use a generic bolt that fits. Anyone got advice?
Amp is a Power Acoustik (THERES THE PROBLEM =P) ov1-2000d, the Gothic series.
Too many projects, too little time...
I snapped a screw for my power on my amp. I ended up finding a screw that fit the threads, tightened, and all set. I figure as long as the connection is made to the terminal itself, it should be ok.
2x 10' Polk Momo MM2104
Alpine MRP-M500
Custom Fiberglass Enclosure
4x Polk db 6.5's
RF 450.4
Pioneer DEH-4000UB
Any good fastener shop should have brass grub screws. Might cost a bit though.
Did you strip the screw or the amp? Often it's the amp's terminals that strip first... then you have to go a size up in the grub screw and get one with a coarse thread so it'll self-tap.
10.x volts fo' life!
  • Who's Online   0 Members, 0 Anonymous, 673 Guests (See full list)
