Guys, need some help with a box design
got an itch to hit a comp less than 2 weeks away
have a 2003 Dodge Ram reg cab
some room behind the driver seat - 20"w 16.5"h 13"d
sub - 10" TC Sounds TC9 based driver - 1000w rms (3" vc d2)
amp - Celestra DA2k (2000+ watts @1ohm)
Stock electrical - 136A alt. DieHard upfront, 0ga welding wire, Big 3
not sure if this needs to be here as I'm not shooting for an all out burp box, but I want the box to meter good just to see what this little sub can do :D
I'm thinking sub up, port up (or to the side - behind the center console)
Slot port is preffered (i know Aero's would be better, but I never had luck with them)...maybe external
want to try the tricks such as the resin 45's
can someone help me out with a design for a fee? or just throw some suggestions on internal volume and port dimensions
sub specs
Fs 35
Qts .45
Vas .45cf
xmax 22mm
Any benifit in running a second run of 0ga to the amp in my case? it pretty close, like 9-10' from the front bat....add an optima blue top by the amp? (meter with the car running)
Any input will be highly appreciated
2003 Dodge Ram 1500 - Deep Orange
Build log - Blowthrought with 4 18's http://www.stevemeadedesigns.com/board/topic/122600-4-18s-in-a-dodge-ram-team-sundown-russia/
Sundown Audio SAX125.2 - Sundown PA 10"
Shok-wiring & RCA's
XS Power D6500
Mechman 320A
Sundown Audio Russia
http://sundownaudio....dex.php?/index
http://www.drive2.ru...ram/ram/skillz/ - more about my truck
http://www.youtube.com/user/Gskillz81
Anyone?
Shok-wiring & RCA's
XS Power D6500
Mechman 320A
i believe if you run 4 gauge you can be in the beginner class and you would do well seein as its a regular cab. not completely positive though
2002 Chevrolet Silverado regular cab 3/6 drop
-Alpine cda-9884
-Rockford Fosgate Power 6.5's
-US Amps XT-4000DE V2
-Fi SSD 10d2-for now
sub specs
Fs 35
Qts .45
Vas .45cf
xmax 22mm
in a regular cab pickup, you want the sub firing forward with the port to the side. for better results on the meter, built it with the sub firing forward on the passenger side, and the port firing to the side on the driver side. let the seat up as far as it will go, and have fun.
Owner of BigAss Ports
thanks for the tip! I was wondering if there was a major difference as far as placement is concerned
Shok-wiring & RCA's
XS Power D6500
Mechman 320A
