lost mine today, its been a trooper so far, but after a bit of abuse from 18's it finally gave way
and my domelights...which not only broke the covers and the mounts, but now turn on and off on some strobelight shit on some notes
safelite has some crazy stronger than glass epoxy that will put it back on, but that just means the next weak link will fail, and it wouldnt be new to see a crack in the windshield or even a chip taken out with it
i think mine is just going to be riding shotgun for now, i'd rather have it next to me than have my windshield break
Team DC
Roof rear views move even more than windshield ones. I would know, it was useless until the day it snapped. Back up camera?
* Head Unit: Kenwood KDC-MP732
* iPod Interface: KCA-iP500
* Front Stage: Rockford Fosgate Power T1652-S
* Front Stage Amp: Rockford Fosgate Punch P400-2
* Rear Stage: Alpine SPR-13C Type-R 5-1/4"
* Amp: Rockford T10001bd
* Subs: (2) 15" Rockford P3s
* Front Battery: Optima RedTop
* Back Battery: Kinetic Hc2400
* Wiring: Rockford 1/0
* Big 3: Rockford 1/0
* Enclosure: Idyllic
well i heard that not having a rear view makes u gain a half a decibal :01nocomment8so:
jk
if the auto glass doesnt work, try my idea with a suction cup
Black 1998 Nissan Maxima
1st Setup: 145.8 DB Outlaw @37 HZ On Music Out Of Trunk
2nd Setup: 147.8 DB @42 HZ On Music Out The Trunk
Current Trunk Build:
153.8 DB Outlaw @ 49 HZ Out the trunk (150.8 DB Sealed)
Team gg.
I would say leave it off because if you knocked off once with the stuff from the dealer that means you have to find something stronger this could lead to the glue sticking very well and the actual windshield to crack around where the glue is contacted.
this!... mine fell off and i used 5 minute epoxy from walmart to put it back on... and this happend 2 hours later....
http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774
93 Saturn SC2My system4 SA-15's Walled
2 Cerwin-Vega S2000's
3 Kinetik Hc2000's
Dual 200amp alts.
you guys done with the peepee touching contest or do I need to end it?
i put som tape (like masking tape) around that little metal thing that holds up the rearview mirror, like enough for it to by a snug fit. then i put a couple drops of super glue on it, not too much to where it will just crack because it is on so well. and about a year later...its still on.
Alpine 9886
Polk Audio 6.5 Component db series
Elemental Designs nine.4
JL Audio 1000/1
DC Lvl 4 15" - 3.95 cu ft/tuned to 32 hz
Clarion EQS746
Stinger Voltage Meter
Optima Yellow Top (Front)
XS Power 1200 (Rear)
All KnuKonceptz Wiring
Okay.
So I went Auto Glass today to hopefully get my mirror put on.
The secretary was like,"well our Tech isn't in right now",(I also went in there the day before and I made the appointment for today)
I guess you could say they weren't the best run business i've seen.
So I wait in the waiting room for like 15 minutes and while the secretary messes with my car.
She comes in, says it's fixed, don't adjust it and don't play bass for 24 hours and I should be good.
She also says I should not plug in my wires for 24 hours.. but I can't really plug them in unless the mirror is off :/
Well I'm skeptical but at the same time optimistic.
My car smells like shit though.
I'll have an update tomorrow when I give it the real test.
4 18's, low power and lots of gay fur.
Team gg
Team DOA
My Videos :)
luckily my accord has an adhesive base ... and the actual rearview mirror is removable along wit hthe adjustable arm .... since my mirror fell off with 2 type rs on 1000 RMS i just keep it in the glovebox ... and slide it back on when i hit the freeway.
My 02 Accord Wall Build
2 Sundown Audio Nightshade V1 18s --- 1 SAZ 3500
Sundown Audio 100.4 --- 4 Sundown Audio Neo-Pro 8s
Sundown Audio 125.2 --- 2 Morel MD-12 Tweeters , 2 Selenium ST-200 Tweeters
DC Power 270xp --- 4 XS Power D1200s | 1 D5100R
