Fi Car Audio
Port Size for 2 18 BTL's
2nd2nun
Been scratchin ma head and checkin through this section for the last hour, never dealt with subs this big.. From what I read and what I worked out so far, I dunno what the go is haha
Box is about 16 cu ft
Port is 20 x 10 15 Deep 200 sq inches total tuned to 35 hz, what else can I tune it to and what sizes do people recommend?
Running either 2 RF T2000's or 2 4000's, Depends what they handle..
Help would be greatly appreciated.
-Nath
STN Audio Designs.
200 inches is enough for a pair of 18" BTL's.
Is that 16 ft^3 net volume or gross (before port and driver displacement)? If it is net volume, your port length is correct.
They will handle the 4000's if you know how to determine the limits of the system. And you are going to need to make sure you have the SSF set correctly if you run 4000 watts per sub in a box that big. Otherwise, you will more than likely destroy them from over excursion.
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
So best to make the box smaller eh? Exactly how small should I go with these 18s?
STN Audio Designs.
If you are going to run 4000 watts per woofer, I would shoot for 6-6.5 ft^3 with 200 sqin of port area.
Current system:
Previous systems:
And if I was to run 4 18s with 4 4000's I should just double what you said ye? Now that I checked up on it I got space for 4 if I make a small box..
STN Audio Designs.
And if I was to run 4 18s with 4 4000's I should just double what you said ye> Now that I checked up on it I got space for 4 if I make a small box..
They need 5-10^3ft each so I don't think smaller and more subs would work out. Box is perfect for 2 18's and just remember that they need 12-16" of port per ^3ft
Thats for there recommended 2k watts each, put 4k watts on em in that size box, Wouldnt last long Id assume... Meade himself hasnt got a huge box and hes runnin 4, all though hes got some serious wiring modifications goin on haha!
STN Audio Designs.
Yes. If you can get 6 ft^3 per sub for 4 subs and 360-400 sqin of port area, it will work great.
I think Steve is running his 18's in a pretty small box. . .
Current system:
Previous systems:
Gonna have to spy on his setup a lil more closely :D (Old Setup that is) Might put 3000's on em to be a little safer and do what you said, 6ft^3 per sub and around 400 sq in of port area... Should work out!
STN Audio Designs.
Sounds like it will be LOUD!!!
Current system:
Previous systems:
  • Who's Online   0 Members, 0 Anonymous, 1661 Guests (See full list)
