Alrighty after not bumpin for a month or two I just finished my new box got it all in and it sounds great. I have been noticing a noise coming from my HU when I listen to a CD. When I switch songs on the HU I can her it through the sub or the track loading. Any way to fix this. The HU is a kenwood kdc mp208. I am thinking about upgrading my HU. I want a single din. any suggestions?
1995 Ford Mustang 3.8l V6 5 Speed
Plans:
  • 2 12 inch dc Level 4s
  • DC 2.0k Amp
  • KCA 1/0 Power Amplifier Installation Kit
  • 220 Amp Alt
  • XS Power 12V D925 AGM Battery
  • Stinger Volt Gauge
  • Rockford Fosgate RCAs
  • Box built from birch. Probably tuned to 32 Hz
  • 0 gauge wiring for extra battery
  • Dynamat
“I think everyone should go to college and get a degree and then spend six months as a bartender and six months as a cabdriver. Then they would really be educated.”
Al McGuire
“The only mystery in life is why the kamikaze pilots wore helmets”
Al McGuire
remember this always
Close only counts in horseshoes and hand grenades
you probably have to ground your RCA's and make sure there on a separate run from the amp and the power cable. ex. your power is ran on your right side on the vehicle and run your RCAs on the left side.
Club 150 (15x.x)
Youtube
Future Build:
1x 15" T3 TSNS
2x Sundown Audio SAZ3000d Parellel strapped
my power is on the driver side and my rcas are on the left. I will try grounding it. If it does not work what HU do you suggest I get?
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
grounded them and nothing changed. any suggestions
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
you might have bad diode's in your alternator you might want to have a shop check it out the alternator will charge your battery and everything but if you got diodes goin bad you will get some noise no matter what you do
06 chrysler 300C Hemi
one mmatts dreadnaut 15 powered by a planet audio vx 2200d
fosgate p200 running planet audio 8" midbass drivers and super compression tweeters
stock battery and a stinger spv44
Irragi 300 amp alternator
big 3 1/0
http://www.stevemeadedesigns.com/board/topic/55075-system-in-my-300c/page__view__findpost__p__763656__fromsearch__1
well I went to autozone and they said my battery is bad....... How do I know if they are lyin or not? they could just be tryin to get me to buy another battery
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
did they do a load test? thats how you check a battery if thats what they did then you have a bad cell in your battery time for a new one with the system you might want to consider an upgraded one and have the alternator checked out
big 3 1/0
Ima do the big three for now and wait on the batt
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
sounds good
big 3 1/0
