I have 2 crossover options, which one would you use???
My head unit is an Alpine 9813, I have two amps, the RFP p4oo-4 powers the polk db651's in the doors. The RFP 700s powers my subs. Both of these amps have a crossover on them and so does the head unit. Currently I have the amps set the AP (All Pass) and I use the head unit as my sole crossover. If you were in my position is this the way you would run the crossovers? If im doing something wrong or if anybody has any suggestions PLEASE voice them!! Thanks In Advance!!!
I would set the high end roskford amp on hp and set the rochford amp on the subs on Lp and still use the headunit to boost the crossover points with the head unit too. And set the setting on the amp if it has adjustable crossover point , adjust the amp to there sweet spots were everything sounds best. I hope this help ed Peace
either way. what the above post was saying is, if you use, for example an 80 hz @12db LP on the head unit and 80hz @ 12 db LP on the sub amp you will have a steeper slope of 24db . you could run the crossover point higher at that point if you wanted to. other than that i don't know that it will make a difference which you chose.
1st  SMD "System of the Month" Feb. 2007
Zapco Studio 500 (2)
Zapco Studio 300X
Zapco Studio 204 (2)
(2) FI 12ssd's w/ copper coils
DLS Iridium Tweeters
DLS UR2.5 MidRange
FI. N.7 Midbass
JL Audio TWK 88
Mechman 370A Elite Alternator
  • Who's Online   0 Members, 0 Anonymous, 1121 Guests (See full list)
