its a LONG video but it was a lot of work...check it out if you get an extra 14 min :D
name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="
type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="445" height="364"></embed></object>">
type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="445" height="364"></embed></object>" type="application/x-shockwave-flash" width="425" height="350">
type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>">
type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>" type="application/x-shockwave-flash" width="425" height="350">
modded the mac mini today...
i think it will probably not be affected by the vibration when i am done (for those that asked). I will probably do something to soften up the shock to it but it shouldnt be too bad. If it acts up i will get a solid state HD. It will probably be ok though.
PTcary, no, you dont need a seperate headunit i just prefer to use one and have the carputer be another "source". It can be ran by itself and sound just fine.
Rear doors and dash bezel for the 10.2 started!
Follow my Tweet (Twitter)
ok i have been slacking on the pics so here is what i have been up to.
Please leave comments here:
http://www.stevemeadedesigns.com/board/ind...778&st=1860
thanks!! :hairtrick:
hackin up the power supply to my mac-mini and replacing it with a 12v to 18.5v DC/DC converter (Carnetix cnx 2140)
10.2" Touchscreen for my dash -
Time to get started on the rear doors. I want MOST of my sounds coming from up front, but since this is STILL a TAHOE, i had to put something in the back doors. I figure this is perfect, one set of seperates....its a lot of work for just one set but its fine, the front is where i sit!
thanks!!
:hairtrick:
I used Flex Filler and some glass to give it structure inside that annoying grove at the top. I also used it to make the "transition" from where i stopped my fiberglass to where the top of the panel is. When i am done you wont even know i stopped the fleece and fiberglass in that spot.
thanks!!
:hairtrick:
thats it for tonite, back at it first thing in the morning!
thanks!!
:hairtrick:
i tried to put up a video last nite after work but windows vista stopped and wouldnt reboot FTMFL!!! I know it wasnt HARDWARE because i dropped windows 7 on top of it and its all brand new again - but by the time i got it dialed in and my main programs back up, it was too late. Here is the pics, this afternoon i will post the actual video.
Rock is always by my side when i am working....
Time to make the back side strong. I dropped as much 29oz fiberglass and resin as i could get in there - it is like granite now!!
Door locks and heated seat control - the door panels from the wrecking yard musta been LS not LT or something because they didnt even have the hole for the heated seat button. It does now though :)
thanks!!
:hairtrick:
heres a vid of the rear door panels being built as well as more sanding etc and another primer job - they are about ready for wrapping after i sand a LITTLE more
Q Logic Kick panels in!
they sound great and it was DAMN easy!
If your a member here, click that Q logic link up top, i think they got a deal going right now.
thanks!!
:hairtrick:
Got started on my dash. I really need to get this thing going now that i took the N1 out. The wires are still there i can still use it if i want but once the screen is in i HAVE to put my new deck down bottom. I bought that single din pioneer but i changed my mind i want double din down bottom. Anyway here is how the dash is coming along.
thanks!!
:hairtrick:
This topic is now closed to further replies.
  • Who's Online   0 Members, 0 Anonymous, 1040 Guests (See full list)
