Ouch
toad420
So earlyer this summer my kicker 650.4 got a little hot and burnt up. I was a Electrical Engineering student for 2 years so I know a little about the specific components in an amp. I took it apart and saw that it was a piece I haven't worked with before and about 10 of the same one fried.
This is a picture from ROE(the amp guts section). I had my friend take close ups that I'll try to post tomorrow but he is having problems with his camera so not sure. Hopefully one of you guys can tell me what these are and if i'd be able to replace them.
Thanks,
Austin
Those are FETs (field effect transistors). easy fix....
4 15" dc audio level 4 xl's in 4th order blow through
2 IA 40.1's at 2 ohms strapped with 3.9 rise...currently own 4 IA 40.1s.....
1 06zx3504 running Kicker QS 6 1/2's
1 iraggi 180 amp alt
1 optima d34 yellow top under hood
5 deka intimidators
HU - Eclipse AVX5000 W/ DCU-105
Termlabed 157db at 38hz 6000 watts
ya you buy those online just make sure when you do you tell them to give all of them from the same lot so that they have similar properties. its not good to mix and match transistors if the resistance or them isnt close to each other some will work harder there for causing them to blow quicker
2 15 RE SE
1 Audiopipe 1500d
Sony HU
Batcap 800 in the back
Team Tex~Flex
thanks guys for the quick replys. know of any good online stores that sell them? i got the part number off a couple of the good lookin ones but google is not being a friend.
Whats going on with the amp? Usually there is more to a blown amp then what is visually seen...
check out this site for parts
http://mouser.com/
First came the quiet
Then came the smell
Then I saw the smoke
And here we are. I might be pickin up a cheap pioneer 4 channel so if anyone is interested in this kicker let me know
I'm not even going to start... well maybe just a little...
You almost certainly can't just replace the obviously smoked parts. So much other stuff you have to check... and they probably smoked because an output channel blew and went short (probably without any visible damage to the parts)
Without a scope, I wouldn't bother. You can try but it might just blow up in your face the first time you put power to it.
10.x volts fo' life!
I know my electrical stuff and I have access to K State EE labs so I have all the tools I would need to find exactly what parts went bad. To fix a burnt up amp you gotta start with whats burnt. I've just decided its more time than I care to spend on fixing it when I can just buy another. i'm sure replacing these burnt pieces would make the thing blow up..........
  • Who's Online   0 Members, 0 Anonymous, 742 Guests (See full list)
