http://www.onlinecarstereo.com/CarAudio/Pr...ProductID=12144
Do you get a pair or just one woofer one tweeter and a crossover.
It may sound really stupid but i am a little scetchy about the title "5.25" 2-Way QSD Series Separate Components"
saying seperate components.
And also, does anyone know if you can wire tweeters toa two ohm load?
Baylor University
Accounting
Sensitivity: 85 dB
RMS Power Range : 70 Watts
Peak Power Handling: 150 Watts
Frequency response: 50-32000 Hz
Diameter: 5.25 Inch
Features
Impedance: 4 Ohms
Frequency Response: 50-32k
Sensitivity: 85 dB
Power Range: 70-150 watts
Crossover Freq: 2400Hz Hz
QTD 25 Tweeter 1" (25mm) Q Series Neo/Al Tweeter
QWD 130 Midrange 5.25" (130mm) QSD SeriesMidrange Driver
QXD 213 Xover BTT MUSiCOMP Crossover for the QSD 213
MOUNT: 25NX SURFACE Rings Surface Mounting Ring for 25NX Tweeters
MOUNT: 25NX ANGLE Rings Angle Mounting Ring for 25NX Tweeters
MOUNT: 25NX FLUSH Rings Flush Mounting Ring for 25NX Tweeters
QM 130.78 AUFBAU Mounting Kit Raised mounting ring (.47") for 130.03KX
QM 130.79 MS EINBAU Mounting Kit Flush Rings & Grilles for 130TX-3
Priced per pair
Component speakers are usually come as a pair unless noted differently.
Warranty: 1 Year Onlinecarstereo.com warranty.
1 Year warranty from Onlinecarstereo.com implies that repairs must be returned to Onlinecarstereo.com, not the manufacturer. More information can be found in our help section under returns & warranties.
Solved that problem! Next! :D Oh yes, you can wire tweeters to a 2ohm load. I think Meade has some in this configuration. B)
1- T1000.1bd's
3 Maxx 29 deep cycles
4 runs of 1/0 gauge
-Big 3
All in a CAR.
Thanks, yea i saw that but i wanted to be reassured before i drop 300 on them. And yea, it looks that way on his diagram...
thanks bro
Baylor University
Accounting
No problem man.
1- T1000.1bd's
4 runs of 1/0 gauge
-Big 3
All in a CAR.
how many watts RMS can those tweeters take, 70 Watts? figured that was just for the woofers...?
Baylor University
Accounting
Well since they are components & come with a passive crossover system to separate high frequencies from low/ vice versa you will have a single 70watt RMS input connected to the crossover which it will then split accordingly to the woofer & tweeter outputs.
1- T1000.1bd's
4 runs of 1/0 gauge
-Big 3
All in a CAR.
oh, i see, I ahve obviously never dealt with component systems before.
So the woofers wont be getting 70 Watts RMS, the woofer and the tweeter will be sharing hte 70 Watts then?
Thanks for the info.
Would all this come in the manual of the components?
Baylor University
Accounting
Yes, MB Quart will definately tell you exactly how to set them up, but really they are a piece of cake once you have them in your hands.
1- T1000.1bd's
4 runs of 1/0 gauge
-Big 3
All in a CAR.
was that yes the answer to this question...
So the woofers wont be getting 70 Watts RMS, the woofer and the tweeter will be sharing the 70 Watts then?
Baylor University
Accounting
Most certainly my fellow comrade.
1- T1000.1bd's
4 runs of 1/0 gauge
-Big 3
All in a CAR.
