Big 3 question
Well I am finally upgrading to the big 3 for the cavi and was wondering is it ok to run the battery negative directly to the engine block. The reason I ask is because of how the stock wiring is. IDK how they did it but the pictures will basically show ya what I am dealing with.
Nearly got my had stuck getting this one
the chassis to the engine block
Could I just get a new screw and nut and bolt them both on top or bolt the battery negative to the chassis on top and the chassis to the engine block on the bottom?
1995 Ford Mustang 3.8l V6 5 Speed
Plans:
  • 2 12 inch dc Level 4s
  • DC 2.0k Amp
  • KCA 1/0 Power Amplifier Installation Kit
  • 220 Amp Alt
  • XS Power 12V D925 AGM Battery
  • Stinger Volt Gauge
  • Rockford Fosgate RCAs
  • Box built from birch. Probably tuned to 32 Hz
  • 0 gauge wiring for extra battery
  • Dynamat
“I think everyone should go to college and get a degree and then spend six months as a bartender and six months as a cabdriver. Then they would really be educated.”
Al McGuire
“The only mystery in life is why the kamikaze pilots wore helmets”
Al McGuire
remember this always
Close only counts in horseshoes and hand grenades
I have always ran it to chassis and another to engine. I think it would be better to go to chassis rather than block, seeing chassis is ground for everything including the engine. Just my 2 cents.
Alpine CDA-9847 HU
F Highs 2x Infinity Kappa 60.9CS Powered by Eclipse EA4200 Glass door panels
R Highs Infinity Ref. 9622i powered by HU
3x RF Punch HX2 RFD2210 Powered by MTX Thunder 81000D
Box Vol. 3.259 before displacement, Tuned 36.6, Port area 54"
So just run one to the chassis. If it works then great. Any other Ideas
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
How about running the battery negative to that bolt and nut ant another form the battery negative to the engine block
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
  • Who's Online   0 Members, 0 Anonymous, 960 Guests (See full list)
