Wassup everyone. Im looking into Battery isolators. Im not sure if they are they are the best route to go but I figured you guys would know. If I'm correct, the isolator 'isolates' the batteries from each other. This is done so that if one battery is pulling more power from the system only that battery will be recharged, versus both of them, improving charging time and over all performance. However I have heard that the isolators dont last that long and dont provide the best option. It seems as if it should work better than just strapping a whole bunch of batts together and charging them at the same time.
Currently Im running about 1500 rms off of my factory alt and bat. I have found one isolator,Tsunami PP2001-PT, which seems the easiest to install since I have a optima bat
http://www.sonicelectronix.com/item_14764_...+PP2001-PT.html.
So.. my question is. Is it worth it? Will the battery isolator really improve my situation? Thanx for the help!
Current build:
Pioneer AVH-P3100DVD
Soundstream EQ
RF Components (5 1/4, 6 1/2, 6x9 x 2)
Two Fi-BTL 15's
One RF T1500-1bd Amplifier
T400-4bd
XS Power 608
XS Power D1200
Optima Yellow top 34
Soon to come:
Another RF T1500-1bd
HO Alt
1-6 more XS power 680
Team D.M.V
no, don't bother.
* Head Unit: Kenwood KDC-MP732
* iPod Interface: KCA-iP500
* Front Stage: Rockford Fosgate Power T1652-S
* Front Stage Amp: Rockford Fosgate Punch P400-2
* Rear Stage: Alpine SPR-13C Type-R 5-1/4"
* Amp: Rockford T10001bd
* Subs: (2) 15" Rockford P3s
* Front Battery: Optima RedTop
* Back Battery: Kinetic Hc2400
* Wiring: Rockford 1/0
* Big 3: Rockford 1/0
* Enclosure: Idyllic
if you use an isolator only the back battery will be drained from the amp(s) and it can only be recharged if the front battery is fully charged.... this makes your chances for voltage drop greatly increase... its not a good idea
this is just my understanding of it... someone correct me if im wrong...
http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774
93 Saturn SC2My system4 SA-15's Walled
2 Cerwin-Vega S2000's
3 Kinetik Hc2000's
Dual 200amp alts.
you guys done with the peepee touching contest or do I need to end it?
absolutely no point in battery isolators unless you play your system with the car off (for shows for example) because it will ruin the alternator to have it charge a very low voltage battery.
my 2 cents
Ok so what would be the best route to go? Im planning on upgrading Big 3 soon and I dont really want to get a new alt. More batts???
Current build:
Soundstream EQ
Two Fi-BTL 15's
T400-4bd
XS Power 608
XS Power D1200
Soon to come:
HO Alt
Team D.M.V
Isolator is not needed, but the thing you pictured isnt an isolator, its just a fancy distro made for an Optima. You can still use that if you want.
XS POWER Batteries, Chargers & Accessories
888-4XS-POWER
Naw Dont want it if its not a isolator
Edited by Mac58
Current build:
Soundstream EQ
Two Fi-BTL 15's
T400-4bd
XS Power 608
XS Power D1200
Soon to come:
HO Alt
Team D.M.V
Either way.. What would be the best way to secure more power for my car withought upgrading alt?.
Current build:
Soundstream EQ
Two Fi-BTL 15's
T400-4bd
XS Power 608
XS Power D1200
Soon to come:
HO Alt
Team D.M.V
Wait. I think ur right scottie J... :shot:
Current build:
Soundstream EQ
Two Fi-BTL 15's
T400-4bd
XS Power 608
XS Power D1200
Soon to come:
HO Alt
Team D.M.V
  • Who's Online   0 Members, 0 Anonymous, 3609 Guests (See full list)
