FS: Kicker KX650.4 - $175 OBO
E-MAIL ME IF INTERESTED : [email protected]
If you have an offer MAKE IT... I will not answer a PM that says "What is the lowest you will take?"
This amp has been tested on my bench and is guaranteed not to be DOA. No further warranty is expressed or implied. The item must be tested in no more than 5 days after receiving it -- do not e-mail me 2 weeks later... If you don't have the time or capability to test it within 5 days then don't buy here.
# 4-channel car amplifier
# 120 watts RMS x 4 at 4 ohms (170 watts RMS x 4 at 2 ohms)
# 325 watts RMS x 2 in bridged mode (4-ohm stable in bridged mode)
# cooling fan
# 2-, 3-, or 4-channel output
# CEA-2006 compliant
# Tri-way capable (Tri-Way crossover required)
# speaker- and preamp-level inputs
# variable front and rear high-/low-pass crossovers (variable 50-200 Hz, 12 dB per octave)
# variable bass boost (0-18 dB) centered at 40 Hz with wired remote control
# three-way protection circuitry
# requires 4-gauge power and ground leads and an 80-amp fuse — wiring and hardware not included with amplifier
# 22-1/2"W x 2-9/16"H x 9-15/16"D
- Jacob Fuller
- Owner, Sundown Audio
- Sundown Audio on FACEBOOK
- Please DO NOT PM ME -- use my email address -- [email protected]
This topic is now closed to further replies.
