Is it blowing fuses on the amp or on the inline power wire on going to the amp?
My comp setup (Not bad for what it is):
HP Compaq Presario V6120US laptop with:
15.4" widescreen
AMD Turion 64 X2 1.6GHz processor
2x1GB stick DDR2 SDRAM (667 Mhz)
Seagate Momentus 500GB SATA HDD
128MB shared video memory
Windows 7 Home Premium 64 bit
12 cell Lithium Ion battery (actual battery usage time: 6 hours)
What it does:
On a USB 2.0 Wireless card
the amp fuse is a 150 which blew twice the one under the hood is a 250 that one didnt blow but it did get red
On the amp or inline? And 150 is a bit small considering those Rockford amps do about 2000 RMS. What size power wire are you running?
15.4" widescreen
What it does:
The amp came with a 150 in it and the specs call for it as well. The wire is 1/0 gauge and the fuse on the power line is 250
So the fuse on the amp blew... How did you set the gains? By DMM, O-scope, or by ear?
15.4" widescreen
What it does:
That 150 amp fuse should be fine.... Both of the T-1ks i used never pulled more than 100 amps of current, amp defective?
Oh, for some reason I though it was a T1500. My bad. I fail at reading... But if he drove the amp into clipping, it could blow the fuse. Not likely, but maybe.
Edited by 1992Chevy K1500
15.4" widescreen
What it does:
the gain was set to the lowest point on the amp and onthe bass knob the HZ was also set low to about 40... I was planning on tuning it by ear but as soon as it saw power the fuse at the amp burned. I bought it used from someone on another forum. Does anything looked messed up in the pictures from original post?
first thing that popped into my mind was a strand of power wire grounding out somewhere on the body of the car or frayed wires on the amp battery terminals touching ground and + together
