i got a 70 watt audiovox amp hooked up to 2 speakers but when i start my truck it has a noise like the motor playing threw them when the radio is on zero. is it rca jacks or wat?
check ur rca's, and ground. maybee you even put a screw threw an rca during install.
////Alpine, Eclipse, Load Boss, Pheonix Gold, MB Quart,Digital Desings, Memphis, Stinger, Periphial, MTX, Visualogic
i took them back out to inspeck them and no damage to them, ill check ground and try another set of rcas today
I had a problem with that and it was just my battery had a bad ground in my trunk. Do you have a 2nd battery? Run your power with your rcas? Check all your grounds and if you need to move your power wire
one battery no subs just mids and highs,rcas are ran in the center between 2 seats and power rain on passenger side of truck, going to go check grounds right now
http://www.stevemeadedesigns.com/board/ind...showtopic=51975
Check this thread out, it should have everything covered.
I had the same problem and this thread helped me out :good: my problem was i needed to ground the rca's.. thats where i would start..
2000 GMC sierra 1500 ext cab
KMC XD Spy series rims
Front doors Fosgate punch 6 1/2's stock tweets
Rear doors Fosgate power 4x6's
Probox 10 and box under rear seat
Rockford fosgate R-500 Prime series amp (537 rms)
4 gauge wiring
ok that helps but now i gota another problem i pulled up my carpet and the foam stuff do i need to run the rca's between the carpet and the foam padding or between foam padding and on the metal?
I ran mine on the metal
4 gauge wiring
