i took them back out to inspeck them and no damage to them, ill check ground and try another set of rcas today
I had a problem with that and it was just my battery had a bad ground in my trunk. Do you have a 2nd battery? Run your power with your rcas? Check all your grounds and if you need to move your power wire
one battery no subs just mids and highs,rcas are ran in the center between 2 seats and power rain on passenger side of truck, going to go check grounds right now
http://www.stevemeadedesigns.com/board/ind...showtopic=51975
Check this thread out, it should have everything covered.
2 - Audiopipe AP30001Ds
1 - Lanzar Opti Scion 600.4
4 - Lanzar Optidrive 1232D's
1 - Lanzar Opti 5.1
1 - Lanzar Opti 6.1
1 - Lanzar Opti 6C midbass
1 - Alphasonic PCT6551
1 - Lanzar VX830
1 - JBL 22 band EQ
1 - Lanzar SDBT75NU
1 - AudioControl Epic160
I had the same problem and this thread helped me out :good: my problem was i needed to ground the rca's.. thats where i would start..
2000 GMC sierra 1500 ext cab
KMC XD Spy series rims
Front doors Fosgate punch 6 1/2's stock tweets
Rear doors Fosgate power 4x6's
Probox 10 and box under rear seat
Rockford fosgate R-500 Prime series amp (537 rms)
4 gauge wiring
I ran mine on the metal
4 gauge wiring
