I know when i installed mine in the burban i had the same problem ,after checking into it there is the power antenna (wrong wire) and the remote wire i had the power antenna hooked up and it would turn the amp on in radio mode but shutoff on ipod or cd mode. my hu is the alpine cda 9886 i know this doesnt help with your headlights on off thing wonder if you hooked up the remote wire to your illumination lead behind the hu on the factory harness this would be my bet. :fool: also might i ad when i bought the truck it had a pioneer dvd9 hu in it that had no faceplate and when i bought the new unit to install i found that the moron that installed the previous unit cut the factory harness off and wired it up so i had a huge mess to figure out junk yard FTW!!!
Edited by yoda132
99 suburban
20" boss motorsport wheels
big 3 installed (thanks Iraggi)
alpine 9886 deck
kenwood 11 band eq
fosgate t5002 amp running sub
kenwood ps200 amp running components
jl xr components in front doors
jl xr 6.5 in rear doors
jl in rear roof
1 FI Q 18" with bp
enclosure 8 cubes 138 sq" port 34hz
Iraggi 220 ho alt
(RF 1500bd coming soon)
dude you need to not be cheap go buy the harness you need its like 15 dollars. wire the other one back up than wire the new harness to the radio and plug up. you got some wire somewhere mixed up in your wires.
Every time I have seen someone hack off their factory harness (at least once a week while I was at Best Buy) they would cut so close to the harness you could never hook it back up. You can get a reverse harness and hook it up, but they are color coded with the standard aftermarket radio colors, so if you wired the HU wrong, you will probably wire the reverse harness wrong. Plus a reverse harness costs as much as a normal harness so you are now paying $40 instead of $20.... Just use the wiring list off the12volt ^i linked it above^ and make sure your connections are good... Check everything with a meter first. if that doesn't work and everything metered properly then your HU is broken.
CAUTION!
POOR INSTALLATION MAY SHORT BOTH YOUR SYSTEM AND WALLET
Hmm good point. I think you may be right about the remote turn on/illumination wire. My headlight switch also turns on the dash and interior lights. I am going to recheck everything. I have the wiring diagram for the hu and for my trucks factory radio. I will make sure it is matched up.
My 93 chevy truck Orion HCCA 15's Build
6K HID's
2 orion HCCA 15.4
2 AP30001D's
2 optima yellowtops, 2 C&D 270fr's, all 3 tsunami 1/0, CS144 190 amp
Rockford p200-2
Rockford p200-2
Rockford p300-1
Kole KX1 5500D -broken
well? did you figure it out?
99 suburban
alpine 9886 deck
kenwood 11 band eq
jl in rear roof
1 FI Q 18" with bp
Iraggi 220 ho alt
  • Who's Online   0 Members, 0 Anonymous, 3033 Guests (See full list)
