ok, this has me stumped.
When the head unit is in radio mode, neither one of my amps are on (same REM turn on wire) but then, if i turn my headlight switch on, both amps will turn on and work fine.
Basically {headlights on--amp on}---{headlights off---amp off} WTF!!!
(btw its a 93 chevy silverado 350 4X4)
It only does this in radio mode. CD and AUX work fine and it doesnt matter if the headlight switch is on or off.
The only thing I can think of is the ground power is running throught the headlight circuit? I have upgraded my batt-frame wire to 4 gauge and all the other grounds are good.
ANY IDEAS what the heck is going on??!
My 93 chevy truck Orion HCCA 15's Build
6K HID's
2 orion HCCA 15.4
2 AP30001D's
2 optima yellowtops, 2 C&D 270fr's, all 3 tsunami 1/0, CS144 190 amp
Rockford p200-2
Rockford p200-2
Rockford p300-1
Kole KX1 5500D -broken
I believe you have something hooked up wrong
what type of radio, was it installed using a harness adapter, try doing it with the antenna disconnected. be careful that if you used a harness adapter that the illumination wire (or dimmer wire) is taped off
SMD SuperSeller VerifiedJbondoXJames Shields
I did not use a wiring harness because I was cheap, but Im pretty sure i did not mess the wiring up because then i dont think it would work in cd & aux mode. But I will try disconnecting the antenna tomorrow.
6K HID's
2 orion HCCA 15.4
2 AP30001D's
Rockford p200-2
Rockford p200-2
Rockford p300-1
Well how did it go?
I am betting with no harness that it was mis-wired.
  • 4 weeks later...
The antenna thing didnt work. I think somehow a wire is getting power when i turn the headlights on. This in turn, is powering on the remote turn ons for the amps
6K HID's
2 orion HCCA 15.4
2 AP30001D's
Rockford p200-2
Rockford p200-2
Rockford p300-1
my friends car does that too. exept the headlight thing (as far as i know). his sony did it. i chaged his deck and it worked fine. little while later it started again. amps dont work with the radio on... ive tried asking about that on forums and never got an answer.
dude you need to not be cheap go buy the harness you need its like 15 dollars. wire the other one back up than wire the new harness to the radio and plug up. you got some wire somewhere mixed up in your wires.
  • Who's Online   0 Members, 0 Anonymous, 3033 Guests (See full list)
