Mac58 Posted September 6, 2009 Report Posted September 6, 2009 Ok so currently I have a single 15 T2 D4 subwoofer wired to 2 ohms on a T-15001bd amp. It puts out roughly 1400+ rms. I also have a T-4004bd amp putting out about 500+ rms. All of this is run off of a stock electrical system in a '06 civic. No major problems until I turn the volume up to about 38, which is ok because I usually have it at about 20. But at 38 the power dwindles. Currently I am upgrading my Big 3 to 0 gauge wire but in case this doesnt help, I was thinking of adding 2 kinetik batts a HC1400 to replace the stock bat under the hood and a HC1800 in the trunk and another stock alt dedicated entirely to the audio system. So I would have a charging system on my regular car and another specifically for my system putting out about 100 amps. I know I could just get a HO for my car but that will run me maybe 400+ but I have a low budget and I have found all the parts excluding batts for less than 250 for the dual alt setup. What are your opinions? Current build: Pioneer AVH-P3100DVD Soundstream EQ RF Components (5 1/4, 6 1/2, 6x9 x 2) Two Fi-BTL 15's One RF T1500-1bd Amplifier T400-4bd XS Power 608 XS Power D1200 Optima Yellow top 34 Soon to come: Another RF T1500-1bd HO Alt 1-6 more XS power 680 Team D.M.V
Dr. Johnson Posted September 6, 2009 Report Posted September 6, 2009 If you can do it the by all means do it.
Mac58 Posted September 8, 2009 Author Report Posted September 8, 2009 Thanx. Anyone else?? Would it be cheaper to just get a HO or what would any of you do in this situation?? Current build: Pioneer AVH-P3100DVD Soundstream EQ RF Components (5 1/4, 6 1/2, 6x9 x 2) Two Fi-BTL 15's One RF T1500-1bd Amplifier T400-4bd XS Power 608 XS Power D1200 Optima Yellow top 34 Soon to come: Another RF T1500-1bd HO Alt 1-6 more XS power 680 Team D.M.V
sully Posted September 11, 2009 Report Posted September 11, 2009 start with the MLA module, then a HO alt. There is no reason to spend $400 on one alternator, i got two of the Mechmans alts for my truck for a little more than that and one for my car for $225. There are a lot of options you just have to figure out the one that is best for you. 2003 Ford F-150 Reg Cab layin body on 26's 2003 Tahoe 3/5 drop on 26's with a 408cid Supercharged engine. 2011 Camaro 2SS 2005 VW GTI Stage II ECU, CAI, 3" turbo back exhaust, FMIC, lowered 2" on some plastidipped 18's 2003 Hayabusa lowered, stretched, cams, nitrous and custom paint
