DC Sound Lab
I would suggest getting better electrical befor ever attempting to run an amp at .5 ohm.. but you could wire it down to .5 and with rise and stuff get it around 1 hm
The DC Integra 3 18s to 6 15 build log
Team_DC-Derrick's Youtube
Team DC Audio
where theres a will theres a wall.......
I just realized Steve has reach Voldemort status, over on JP's site he is the one who will not be named....."We dont speak his name over here, fearing it will destroy us" LOL not even in hush tones
hey i got a lvl 5 18 in a 6.2 box i was wondering if a 2k at .5 ohms would be good? im running 0gauge and only one batt in the trunnk? any tips?? or amps i should run? money is a concern
rise?
Copied this
The DC resistance is the measurement of the coil at rest. When the cone starts moving, the magnetic field associated with the magnet and the moving coil increases the resistance of the voice coil. Usually the more resonant the enclosure, the higher the impedance rise. Most competitors try to factor rise into the equation so they can get the most power out of their amps.
Team DC Audio
Copied this
LOL, that even sorta confused me, also Probably another battery in the back, and a 200-250 amp alt, with Big 3 done, and you should be good to run that amp at .5 safely.
¿ǝɯɐƃ ǝɥʇ
It is adding on to your factory wiring with Larger Guage wire(preferably 0/1)
It involves upgrading
Battery Negative to Chassis
Battery Positive to Alternator Charging wire
And Engine Block to Chassis
This helps the overall flow of electricity in you electrical system and generally yields some gains in charging voltage, also is a must if you are upgrading your alt.
Edit: There is a tutorial stickied in the Electrical/Battery section, look there.
Edited by CaptainzPlanetz
¿ǝɯɐƃ ǝɥʇ
