rival904 Posted September 7, 2009 Report Share Posted September 7, 2009 I had a router I used mainly to cut woofers with using a Jasper Circle Jig, it took foreverrr. I was using a cheap-o 60 dollar Ryobi router, and a harbor freight upcut bit, which was more of the slowdown, the weak router or the bit? Anyways, I want to try to roundover edges and stuff, but everytime I try, I just fail miserably, it is easily the tool I suck the most at, here is an an example of a 3/4 roundover bit used on 3/4in MDF by yours truley. Any tips of things I can do to help my router skills? 2004 Yellow F150 STX 4x4 Single Cab 2 Yellow DC Power 270SP's Alts 4(and counting) XS Power 6500's 4 DD3515s Supercharged 53cu.ft 4th order blowthrough 8 DD M1b's 6 Selenium 8's 2 Selenium ST350s 154.1 @ 41hz Legal Burp Build Log Link to comment Share on other sites More sharing options...
john denver Posted September 7, 2009 Report Share Posted September 7, 2009 (edited) dont set the bit so deep it will claen up the edges wont leve the line all the way around just practice with scrap till you get the hang of it Edited September 7, 2009 by john denver Link to comment Share on other sites More sharing options...
indytrucks Posted September 7, 2009 Report Share Posted September 7, 2009 Looks to me like the depth of the bit is too much. Is the bearing the right size? Link to comment Share on other sites More sharing options...
rival904 Posted September 7, 2009 Author Report Share Posted September 7, 2009 Well like I said, that was my first time trying to use a roundover bit, I mainly use the jasper jig but I wanted to play around. 2004 Yellow F150 STX 4x4 Single Cab 2 Yellow DC Power 270SP's Alts 4(and counting) XS Power 6500's 4 DD3515s Supercharged 53cu.ft 4th order blowthrough 8 DD M1b's 6 Selenium 8's 2 Selenium ST350s 154.1 @ 41hz Legal Burp Build Log Link to comment Share on other sites More sharing options...
-Hobby- Posted September 7, 2009 Report Share Posted September 7, 2009 (edited) On a complex curve like that you cant use a 3/4" roundover on a 3/4" piece of stock. There is nothing for the bearing to ride on. If you do use a 3/4" bit you will have to leave the bit raised somewhat so the bearing can ride on the edge. That or use a smaller radius roundover. Edited September 7, 2009 by HobbyWerks Link to comment Share on other sites More sharing options...
Derrick824 Posted September 8, 2009 Report Share Posted September 8, 2009 All you do is clamp the two sides together before assembly so that the bearing rides on the other side. When doing a project like this & you want both sides to match it's a good idea to free hand the first side then use it as a template to cut the other side using a flush bit. Link to comment Share on other sites More sharing options...
rival904 Posted September 8, 2009 Author Report Share Posted September 8, 2009 I understand, so without anything for the bearing to ride on, the bit is useless? PS - Where you @ the Jax show with the Excursion? 2004 Yellow F150 STX 4x4 Single Cab 2 Yellow DC Power 270SP's Alts 4(and counting) XS Power 6500's 4 DD3515s Supercharged 53cu.ft 4th order blowthrough 8 DD M1b's 6 Selenium 8's 2 Selenium ST350s 154.1 @ 41hz Legal Burp Build Log Link to comment Share on other sites More sharing options...
98crewcab Posted September 8, 2009 Report Share Posted September 8, 2009 I understand, so without anything for the bearing to ride on, the bit is useless? PS - Where you @ the Jax show with the Excursion? EXACTLY:) 06 2500hd, 6.0L, 4l80e, 4wd, (muah work truck) 7" BDS HC lift kit (5) 37x13.5R18 Toyo Open Country M/Ts (5) 18x10 Moto Metal MO962 tablet in lieu of deck blue tooth interconnect to soundstream eq (for volume control and bass control) 4 Alpine type r 10's 6 cubes net, 80sqin's port, tuned to 33hz 2 brutus brx5000.5's 2 pairs 3" polk audio for a pillars 4 pairs polk audio 6.5 comps 1 pair 8" polk audio for mids 2 xspower d3400 batteries.....learning alot from meade and his circle of some of the baddest installers ive seen- thanks guys, for not being so cocky and posting the way it should be done!P.S. Thanks Steve....for the demo!!!! loud as fauk! Link to comment Share on other sites More sharing options...
-Hobby- Posted September 8, 2009 Report Share Posted September 8, 2009 I understand, so without anything for the bearing to ride on, the bit is useless? PS - Where you @ the Jax show with the Excursion? Not I sir, sorry. You can also do as Derrick suggested but that would have to be done before you put the box together. that and drop your router base down a bit so you dont cut too deep with the bit and leave the depression on the surface. Should be a smooth transition to the sides of your box. Unless you were doing that to leave a gap to staple into for fiberglassing. Just a guess. Link to comment Share on other sites More sharing options...
rival904 Posted September 8, 2009 Author Report Share Posted September 8, 2009 Oh ok. I was talking to derrick about the jax show. 2004 Yellow F150 STX 4x4 Single Cab 2 Yellow DC Power 270SP's Alts 4(and counting) XS Power 6500's 4 DD3515s Supercharged 53cu.ft 4th order blowthrough 8 DD M1b's 6 Selenium 8's 2 Selenium ST350s 154.1 @ 41hz Legal Burp Build Log Link to comment Share on other sites More sharing options...
