Router Questions
I had a router I used mainly to cut woofers with using a Jasper Circle Jig, it took foreverrr. I was using a cheap-o 60 dollar Ryobi router, and a harbor freight upcut bit, which was more of the slowdown, the weak router or the bit?
Anyways, I want to try to roundover edges and stuff, but everytime I try, I just fail miserably, it is easily the tool I suck the most at, here is an an example of a 3/4 roundover bit used on 3/4in MDF by yours truley.
Any tips of things I can do to help my router skills?
2004 Yellow F150 STX 4x4 Single Cab
2 Yellow DC Power 270SP's Alts
4(and counting) XS Power 6500's
4 DD3515s Supercharged
53cu.ft 4th order blowthrough
8 DD M1b's
6 Selenium 8's
2 Selenium ST350s
154.1 @ 41hz Legal Burp
Build Log
Well like I said, that was my first time trying to use a roundover bit, I mainly use the jasper jig but I wanted to play around.
8 DD M1b's
6 Selenium 8's
2 Selenium ST350s
Build Log
On a complex curve like that you cant use a 3/4" roundover on a 3/4" piece of stock. There is nothing for the bearing to ride on. If you do use a 3/4" bit you will have to leave the bit raised somewhat so the bearing can ride on the edge. That or use a smaller radius roundover.
Edited by HobbyWerks
I understand, so without anything for the bearing to ride on, the bit is useless?
PS - Where you @ the Jax show with the Excursion?
8 DD M1b's
6 Selenium 8's
2 Selenium ST350s
Build Log
EXACTLY:)
06 2500hd, 6.0L, 4l80e, 4wd, (muah work truck)
7" BDS HC lift kit
(5) 37x13.5R18 Toyo Open Country M/Ts
(5) 18x10 Moto Metal MO962
tablet in lieu of deck
blue tooth interconnect to soundstream eq (for volume control and bass control)
4 Alpine type r 10's
6 cubes net, 80sqin's port, tuned to 33hz
2 brutus brx5000.5's
2 pairs 3" polk audio for a pillars
4 pairs polk audio 6.5 comps
1 pair 8" polk audio for mids
2 xspower d3400 batteries
.....learning alot from meade and his circle of some of the baddest installers ive seen- thanks guys, for not being so cocky and posting the way it should be done!
P.S. Thanks Steve....for the demo!!!! loud as fauk!
Not I sir, sorry.
You can also do as Derrick suggested but that would have to be done before you put the box together. that and drop your router base down a bit so you dont cut too deep with the bit and leave the depression on the surface. Should be a smooth transition to the sides of your box. Unless you were doing that to leave a gap to staple into for fiberglassing. Just a guess.
  • Who's Online   0 Members, 0 Anonymous, 1149 Guests (See full list)
