Need help with voltage
So I posted before with the same problem but I am still having pretty bad voltage drop and dimming. I now have a DC 275amp alt , xs power D5100r up front and the big 3 in 1/0. I am running a Sundown 1200d amp which is 1200 rms at 12.8 volts, and I am running 4g from bat. pos to amp and 4g ground on amp(I believe 4g is that max size for the 1200d). I have checked all my grounds with a DMM and my highest resistance was 1.0 exact.
My lights dim pretty much every time the bass hits but it is mainly a flickering(even when the bass and volume is turned down the lights blink a little). According to the DMM I am dropping just below 11 volts (from 13.8v) at full tilt and the amp shuts off. I have been told that the alt may be bad but I have never heard of a DC power alt. go bad. I have also been told to run 1/0 to the amp but I think 4g is the maximum size. I have no clue what to do or whats going on so I really would appreciate the help a ton. By the way the problem seems to be getting worse but that could just be me.
04 Armada. Lifted 35" Toyo MTs.
Sundown 1200saz
Fi Bl Fully Loaded
you said you checked all the grounds. did you check to see if the battire was still good just a suggustion
~2006 chrysler Sebring~
~2 runs of 1/0 front to back~
~1/0 wire for "big 3"~
4 spl-hx 12'' dual 2
2 dtr 1.3400
3 c&d terminologies 1000s
100 aH Each
piccso 6.5 comps
pinoeer avh 4900dvd
pioneer xm box
blue gauges
custom dave the box guys box
new stuff on the way
Team
Soundstream
Yep I checked them. Unless the DMM was incorrect. Yeah I checked the voltage of the battery and it was at 12.8 which is the same as when I bought it and it is holding charge so... I just feel like my eletrical should easily hold up to 1200 rms.
Sundown 1200saz
Fi Bl Fully Loaded
email DC power. could be the alternator. maybe the battery is shot and cannot output any current but its voltage is fine.
throwing out ideas
load test that battery, it can show a good voltage but won't pass a load test. Autozone should do it for free if you don't have the equipment
2003 Ford F-150 Reg Cab layin body on 26's
2003 Tahoe 3/5 drop on 26's with a 408cid Supercharged engine.
2011 Camaro 2SS 2005 VW GTI Stage II ECU, CAI, 3" turbo back exhaust, FMIC, lowered 2" on some plastidipped 18's
2003 Hayabusa lowered, stretched, cams, nitrous and custom paint
Alright went to get it load tested today at a few places. I got between 450 cranking amps and 475 cranking amps every test. I called XS power and they are suppose to get back with me. That sounds kinda low to me so I would quess that maybe my battery is bad? I checekd their website and I cannot find any specs on cranking amps so I dont know.
Sundown 1200saz
Fi Bl Fully Loaded
  • Who's Online   0 Members, 0 Anonymous, 1027 Guests (See full list)
