Bunker Posted September 11, 2009 Report Posted September 11, 2009 My question is, 4 amps on 4 subs without strapping the amps. I want them to act as masters without using Y splitters, would I run them all as slaves and just let the mlx-100 do the work. J&T DESIGNS M5 4 Audioque 15's copper coils dropping Audiopipe, and picking up DB DRIVE OKUR Powermasters XS POWER Dropping MaxxSonics Pioneer
Bunker Posted September 14, 2009 Author Report Posted September 14, 2009 Bump After today I will just strap them, if no one knows. J&T DESIGNS M5 4 Audioque 15's copper coils dropping Audiopipe, and picking up DB DRIVE OKUR Powermasters XS POWER Dropping MaxxSonics Pioneer
Derrick824 Posted September 14, 2009 Report Posted September 14, 2009 So basically you'll be using the Maxx-Link as a line driver. You can do that no problem. Just use only the rca outputs on the + side.
Cr@sh Posted September 14, 2009 Report Posted September 14, 2009 Question is why? the maxxlink is used for strapping amps and help eliminate phase issue's with running multiple amps. Are your subs all in one enclosure with no divider's, as in mono? My old install at cardomain, never finished!
Bunker Posted September 14, 2009 Author Report Posted September 14, 2009 So basically you'll be using the Maxx-Link as a line driver. You can do that no problem. Just use only the rca outputs on the + side. Thank you. J&T DESIGNS M5 4 Audioque 15's copper coils dropping Audiopipe, and picking up DB DRIVE OKUR Powermasters XS POWER Dropping MaxxSonics Pioneer
Bunker Posted September 14, 2009 Author Report Posted September 14, 2009 Question is why? the maxxlink is used for strapping amps and help eliminate phase issue's with running multiple amps. Are your subs all in one enclosure with no divider's, as in mono? Reason is if I fry one or blow one sub that will be all I fry or blow is 1. Common. J&T DESIGNS M5 4 Audioque 15's copper coils dropping Audiopipe, and picking up DB DRIVE OKUR Powermasters XS POWER Dropping MaxxSonics Pioneer
Andrew2944r Posted September 14, 2009 Report Posted September 14, 2009 Using the Y's allows you to run 5 amps per MLX-100, without the Y's you will need a maxxlink master and one in slave. Either way you just use the A+,B+,C+,D+,E+ on which ever way you decide to wire them up. Team Ampere Audio
audioaddiction863 Posted September 14, 2009 Report Posted September 14, 2009 Its all about the Install !!!! http://www.youtube.com/user/audioaddiction863 Bass Race Florida State Champ runner up 139.9 2008 Bass Boxing Florida State Champ runner up Middleweight 2008
Bunker Posted September 14, 2009 Author Report Posted September 14, 2009 Thanks Guys Mod can now lock J&T DESIGNS M5 4 Audioque 15's copper coils dropping Audiopipe, and picking up DB DRIVE OKUR Powermasters XS POWER Dropping MaxxSonics Pioneer
