the 3000.1 is the only amp crunch makes that does rated and more :) good thing you picked that one.
i think youd be fine with just a single 270 and thats it. few runs of 0 gauge to 3 batteries in the back and the big 3 in 0 gauge
so 3 of the d3100 batts or am i good with the 2?
With the Crunch 3k Pro you'll be fine w/ the single HO alt(like the one listed), good under hood batt (Northstar NSB-40 or similar) and 2 big batts in back(NSB-125, XS 3100, Deka 9a31, etc similar performance batts). As far as HO alts are concerned I'd look into Ohio Generator for all your alternator needs.
1998 Ford Explorer Eddie Bauer... New setup, old ride... QX56 is staying stock til I get loud... It's only getting walled off if I don't meet my goal @ SBN.
Pioneer AVIC-N2
(12) 12" RE SXs old model.... (3) AB VFL 500.1 @ 1ohm each
Dual 300amp Ohio Gen alts.... (10) Northstar NSB-125s
26ft3 @ 33hz w/ a ton of port area
156.5 @ 40hz @ dash, Db Drag style / 153.2 Bassrace
so how do i go about getting one of these alts?
  • Who's Online   0 Members, 0 Anonymous, 630 Guests (See full list)
