EXO Needs YOU! 18" Subwoofer Enclosure Design - Ascendant Audio Mayhem
EXOcontralto
he means changing the ports out
So like port tubes? Like cycliders?
The REAL YouTube Page
●▬▬▬▬★▬▬^๑۩۩๑^▬▬★▬▬▬▬●
Head Unit - Pioneer DEH-p6000ub
Equalizer - Soon To Come
Amplifiers - (4) Soundstream TX1.2600d's
Subwoofers - (2) Soundstream XXX 18's
Enclosure - 16 Cubic Foot Wall Tuned to 38hz
Power Wire - (200ft) Tsunami 0 Gauge PRO
BIG 3 w/ 8 C&D Batteries
Team DBs (Driven By sound)
Like one of these:
Posted Image
Posted Image
This is a single 15 box for my car with a single 8" custom made flared port or aeroport if you will. This is the type of box that I was going to design for you if you wanted. By the way this box has done well over a 152 on the dash in my ZX3 off of just under 4K watts rms.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
That seperation Idea sounds good, it would be nice to see it carpeted with the amps mounted to it, it would look sexy.
¿ǝɯɐƃ ǝɥʇ
Like one of these:
Posted Image
Posted Image
Are these things actually good? What would be optimal?
And wouldn't it be kinda tricky to properlly tune? - how could these ports be interchangable? - And will the sound be affected by the circular tube? It looks odd, but I just want to know what could knock wicked loud - remember, I really want to add another woofer someday,would making this be optimal?
Custom made flared ports are very hard to tune. They need to be cut and refitted to get the tuning right and can be tricky to do. On the other hand Precision ports work well because they come in several pieces and are fitted together with collars and usually duct tape or electrical tape.
They work very well and are easy to take out of a box to cut to adjust the tuning of the enclosure.
For your sub I would say that 5.5 cubes after woofer and port displacement and 2 6" aeroports the stock length that they come would be very nice. It would tune the box to 36hz and would play all day long down in the high 20hz range and would play up into the high 50hz range nicely too. The aeroports have no port turbulence and help the air exit the enclosure better and faster than a slot ported box. They are usually a db louder than a slot ported box with the same specs and power.
1 XS Power D3100
Audio Control LC6i
Stock Deck
^^ true dat. look at my 2 10's on 1500 watts. in my exploder
this vid was taken right after i hooked everything up(subs haven't broken in yet)
name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="
type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>">
type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>" type="application/x-shockwave-flash" width="425" height="350">
So essentially, flared aeroported ported boxes, even though they get[retty loud when done right, are harder to make, harder to tune. and harder to hit a broad span of frequncies?
Would I really want that? SPL wise?
Hey EXO, would you want a box you can change from SPL to everyday? I've seen guys put in special screws and fasteners on slot ports and whatever, so they can interchange the ports in minutes. Correct me if I'm wrong fellas.
isnt meade's box like that? he has a port for daily and a port for comps
I dont think meade does comps anymore so no.
I know that BeaJay with the 4 15" IA Wardens does though.
¿ǝɯɐƃ ǝɥʇ
