EXO Needs YOU! 18" Subwoofer Enclosure Design - Ascendant Audio Mayhem
EXOcontralto
I will design a box for you that is tuned to 34hz with 90 sq inch of port area and 6 cu ft big.
It should be ready in a few hours.
Dimensions: 30 inch wide, 29 inch long, 15 inch high.
Port: 10x9 inch port, lenght:27.61 inch long.
^^^this is close to 6cu ft (with displacement of port and driver.)
I appreciate that mang -
But.....
If the subs can wants' 5 to 8 cubes, wouldn't six cubes before displacement be like 5.75 cubes after displacement?
Isn't that kinda on the small end for it's rec.enclosure?
The REAL YouTube Page
●▬▬▬▬★▬▬^๑۩۩๑^▬▬★▬▬▬▬●
Head Unit - Pioneer DEH-p6000ub
Equalizer - Soon To Come
Amplifiers - (4) Soundstream TX1.2600d's
Subwoofers - (2) Soundstream XXX 18's
Enclosure - 16 Cubic Foot Wall Tuned to 38hz
Power Wire - (200ft) Tsunami 0 Gauge PRO
BIG 3 w/ 8 C&D Batteries
Team DBs (Driven By sound)
But.....
No, I think the box without displacement is higher than 6, maybe even higher than 7 but after port and woofer displacement is should come around to 6 cubes after all displacements.
Edit: kirill007, is that internal or external measurements? If it's external I think it might be too small.
My Official Feedback Thread
PSN - tech2332
Games for PS3: Killzone 2, BattleField: Bad Company 2! Add me to play either!
That's what I was Thinking too - it seems a bit too small for the suggested size dimensions for the woofer -
If I can have a bigger - deeper tuned box - with all my caravan's room - I'd like to have the optimal size for the woofer -
Again it can handle 5 to 8 cubes - I think going somewhere in the middle would be best.
You know what I mean? Just to be safe
But.....
6 cubic feet will be fine for that sub if you send the 3000rms like you said. Subs will want to be in a smaller enclosure usually when over powering them.
It's giing to be less that 6 cubes after displacement - the magnet takes up 0.26 cf
I will have around 3.5k goin to it, but It will not be slammin full-torque on 3.5k -
I will be adding another sub within a few months to cut the load down to size (.5ohm)
That way I will be gettin almost 2.k from each sub
But with that small of a box - as far as lows go - I think it's pushin it
hey exo its jaysmith850 from youtube. heres what i thought up...Posted Image (just go put these dimensions into the re calculator and you'll see what it looks like)...make one box first(sub forward port forward, laying flat) then when when you get youre other sub build another one of the same boxes, and have them ports top facing forward, subs forward(sitting tall instead of flat). of couse you would need some kind of bracing, i would just double up all the walls and possibly triple baffle. whatcha think
justin smith
1996 mercury grand marquis
20'' bentchi b7 lexani n3000 245/35/20
cactus 5kw at 1ohm dcr(beast)
2 18'' btl's in a 14.15^ft wall tuned to 35hz with 210'' of port
kicker zx650.4
componets in still the works
200amp motorcraft alt
xs power d3100 (beast)
kenwood ddx512 h.u.
you mean my EX? the one I dumped? just remember every time you kiss her that i used to cum in her mouth
and BTW your girl just called me....
pure pwnage
Posted Image ...better screen shot for ya, hope it helps
justin smith
kicker zx650.4
kenwood ddx512 h.u.
pure pwnage
hey exo its jaysmith850 from youtube. heres what i thought up...Posted Image (just go put these dimensions into the re calculator and you'll see what it looks like)...make one box first(sub forward port forward, laying flat) then when when you get youre other sub build another one of the same boxes, and have them ports top facing forward, subs forward(sitting tall instead of flat). of couse you would need some kind of bracing, i would just double up all the wall and possibly triple baffle. whatcha think
No ofeense, but I've heard some horror storys about the RE calc.
Is this program really trustworthy?
ive used it on like 5-6 of my boxes. i like it, it always works for me. just trying to help man
justin smith
kicker zx650.4
kenwood ddx512 h.u.
pure pwnage
Really? That's good to hear! - I really appreciate the help - It doesn't look like someone can just whip up some single 18" desgins like I had hoped -
For anyone of those who are just reasding this for the first time -
I have a grand caravan will CRAZY ROOM! - I want a box tuned low - and maybe with the option to have interchangable ports - slotted ofcourse - I have videos of my van, and how much room I can handle in this forum already -
If anyone can whip up a set of plans for 1 18" slot ported box tuned to aroun 30 to 34 hz - That would be amazing - PLEASE HELP!!
  • Who's Online   0 Members, 0 Anonymous, 3765 Guests (See full list)
