SmokeyDog Posted September 12, 2009 Report Posted September 12, 2009 dose it really matter witch way the port fires. should if fire out the same way the subs due witch would be better sub faceing up in all port though rear deck . port though the back of seats in to car. ~2006 chrysler Sebring~ ~2 runs of 1/0 front to back~ ~1/0 wire for "big 3"~ ------------------------------------------------------- 4 spl-hx 12'' dual 2 2 dtr 1.3400 3 c&d terminologies 1000s 100 aH Each piccso 6.5 comps pinoeer avh 4900dvd pioneer xm box blue gauges custom dave the box guys box ------------------------------------------------------------------------------ new stuff on the way Team Soundstream
Guest Posted September 12, 2009 Report Posted September 12, 2009 it all depends on the car. for a sedan its normally sub back and port back. unless you can find a way to seal the box off from the trunk, then point sub and port forward (with seats down). for an SUV/Van. usually its sub up port back. same with hatchbacks.
SmokeyDog Posted September 12, 2009 Author Report Posted September 12, 2009 it all depends on the car. for a sedan its normally sub back and port back. unless you can find a way to seal the box off from the trunk, then point sub and port forward (with seats down).for an SUV/Van. usually its sub up port back. same with hatchbacks. ok well theres no way of fitting 4 12 acrross. i got the box design so that i am at 7.22cubes 38w 34d 15 high with a port 8h 18w 20d tuned down to 33.01hz dose this sound right? just got to figure out to face port thought deck or front cant go to back no room ~2006 chrysler Sebring~ ~2 runs of 1/0 front to back~ ~1/0 wire for "big 3"~ ------------------------------------------------------- 4 spl-hx 12'' dual 2 2 dtr 1.3400 3 c&d terminologies 1000s 100 aH Each piccso 6.5 comps pinoeer avh 4900dvd pioneer xm box blue gauges custom dave the box guys box ------------------------------------------------------------------------------ new stuff on the way Team Soundstream
Basshead08 Posted September 13, 2009 Report Posted September 13, 2009 With those options I would port through the deck for sure. System tear out has begun...Out with the old i have a iq of 128 i graduated at the top of my class tell me how im reatrded you are the 1 thats dumb as hell you can't even spell Look at the underlined text hahahahahahahaha I think of it as the virgin losing the virginity technique not just jumping in to it, and pounding away, but going at it slowly over time, to get to that full extreme
