Kicker L7 vs RE sxx ???
texasbred
the new L7 solo-baric subs tend to Sheer off where the cone is glued to the coil when put under a lot of Stress,
Iv owned a pair of Re Sx 15" sounded great, but cant take a single saz 3000d :(
the Re-sxx your looking at, from the specs seem like a waste of time.
Electrical Q Value -Qes: 0.32
Mechanical Q Value -Qms: 4.4
Total Speaker Q Value -Qts: 0.30
Free Air Resonance -Fs: 30.6 Hz
Equivalent Compliance -Vas: 47.6 liters
One-Way, Linear Excursion -Xmax: 22 mm
Efficiency -SPL 1W/1m: 88.1 dB SPL
Effective Piston Area -Sd: 480 cm^2
DC Resistance -Re: 1.9 ohm
Nominal Impedance -Znom: Dual 2/4 ohm
Thermal Power Handling -Pe: 1000 W
Force Factor -Bl: 21
Mounting Depth - 6.9"
Mounting Hole Diameter - 11.2"
Overall Diameter - 12.5"
Bolt Hole Circle - 11.75"
Motor Width - 7.3"
Motor Depth - 3.44"
Basket Depth - 3.46"
Displacement - 0.16 cu. ft.
Weight - 24.5 lbs
2.0@33Hz
seems kind of small to be ported that low...
but it all comes down to install / the boxx will make or break you
how coincidental my friends shop did the same same 15's but on a planet audio apocalyspe 3000d blew one the guy switched to the panet audio big bang subs never been happier
06 chrysler 300C Hemi
one mmatts dreadnaut 15 powered by a planet audio vx 2200d
fosgate p200 running planet audio 8" midbass drivers and super compression tweeters
stock battery and a stinger spv44
Irragi 300 amp alternator
big 3 1/0
http://www.stevemeadedesigns.com/board/topic/55075-system-in-my-300c/page__view__findpost__p__763656__fromsearch__1
  • Who's Online   0 Members, 0 Anonymous, 2460 Guests (See full list)
