BassAddict32 Posted September 15, 2009 Report Posted September 15, 2009 this is probably gonna sound stupid, but i have a question. if you have a 2 channel amp, you can put the positive to the right channel and the negative to the left channel, and get more power, correct? if you do that for both, like put 1 positive/left negative/right for one sub and negative/left positive/right for the other. will more power be flowing to both then? or will it be the same as putting them on a channel of their own? 1994 Ford F150 reg cab 2 HFX 12's Audiopipe APSM-1300
Guest Posted September 15, 2009 Report Posted September 15, 2009 essentially your bridging the amp if you do that. make sure it can handle it (check the manual) and the safest ohm load to go down to.
BassAddict32 Posted September 15, 2009 Author Report Posted September 15, 2009 essentially your bridging the amp if you do that. make sure it can handle it (check the manual) and the safest ohm load to go down to. alright, but it has the same effect, correct? 1994 Ford F150 reg cab 2 HFX 12's Audiopipe APSM-1300
DUBIE Posted September 15, 2009 Report Posted September 15, 2009 alright, but it has the same effect, correct? by anymeans since your bridging it. your gettting more power out of the amp
skittlesRgood Posted September 15, 2009 Report Posted September 15, 2009 no, you cant double bridge a 2 channel amp. when you bridge you are using both channels to work together to produce more power into one channel. If I answered you in a well mannered, informative way, you asked a good question or had a good attitude. If I was an asshole, you asked a stupid question or you had a fucktard attitude... or I was in a bad mood. Team BassickHU: Pioneer AVIC Z110Front: Peerless SLS 6.5", Peerless HDS 4", Rainbow tweeter - running activeAmp: JL HD600/4 and DC 4 channel (bridged to midbass)Processor: JBL MS-8Subs: 2x 12" AA MayhemsAmp: DC 3kElectrical: DC power 270xp alt. 1/0 big 4. XSpower D3400 and six D680s. http://www.stevemeadedesigns.com/board/topic/121795-29-update-the-buick-is-getting-a-rebuild/ Top career scores: DBdrag 151.7 MECA SQ 82.25My SOTM build Yeah. im pretty sure they dont warranty retarded people.
BassAddict32 Posted September 15, 2009 Author Report Posted September 15, 2009 no, you cant double bridge a 2 channel amp. when you bridge you are using both channels to work together to produce more power into one channel. okay, i get what you mean. so it's not possible. which, i guess does make more sence. 1994 Ford F150 reg cab 2 HFX 12's Audiopipe APSM-1300
