Derrick824 Posted April 30, 2007 Author Report Posted April 30, 2007 (edited) so at 0.5 ohm per coil I'll see a good 2200RMS out of each amp! How'd you get 0.5ohm coils? Aren't the BTLs only offered in dual 0.7ohm & 1.4ohm? We've ran these bx2005d's @ 0.7ohms with one amp per TeamRF (dual 1.4ohm coils in parallel) and the amps did great. They never got hot or went into protection. I haven't posted everything about this build yet because we're still waiting to get the subs in and build the box and I don't like talking about stuff until I'm in process. That way I can post pics if needed. Right now the next step in the build is to install the dual alternator setup and run some more wire through the truck. There is currently two batts up front & two in the rear w/ two runs of 0awg wire run to the back. We'll be adding the second 200amp alt and two more runs of 0awg wire before we begin with the actual box build. I'll make sure and post some more pics then. Edited April 30, 2007 by Derrick824 Quote
